Could someone please take a look at this error log ;
03:12:24.6 20/12/2005: GameEx: Version 5.30: Starting Log
03:12:24.7 20/12/2005: Operating System Platform: Win32NT
03:12:24.7 20/12/2005: Operating System Name: Windows XP
03:12:24.7 20/12/2005: Operating System Version: 5.1.2600
03:12:24.7 20/12/2005: Checking for versions of .net Framework installed
03:12:24.7 20/12/2005: .net Framework 1.1 Installed
03:12:24.7 20/12/2005: Checking Registration
03:12:24.7 20/12/2005: Running Randomize()
03:12:24.7 20/12/2005: Initialising Video/MNG DLL's
03:12:24.7 20/12/2005: Running Misc startup tasks
03:12:24.7 20/12/2005: Setting Menu types
03:12:24.7 20/12/2005: Opening Configuration File
03:12:24.7 20/12/2005: Getting Configuration Values
03:12:24.7 20/12/2005: Using Theme: Default - GameEx - Animated
03:12:24.7 20/12/2005: Checking for alternate Image Directory for Theme: Default - GameEx - Animated
03:12:24.7 20/12/2005: Using Images from theme: Default - GameEx\MEDIA\
03:12:24.7 20/12/2005: Text/Language: English
03:12:24.7 20/12/2005: Applying Language/Text
03:12:24.8 20/12/2005: Creating Scancodes.txt (List of DirectInput scan codes)
03:12:24.8 20/12/2005: Snap Delay set to: 3
03:12:24.8 20/12/2005: Is Media Center running?
03:12:24.8 20/12/2005: Check Media Center Exit/Start Mode
03:12:24.8 20/12/2005: Media Center Mode 0
03:12:24.8 20/12/2005: Checking for applications to Launch On Startup
03:12:24.8 20/12/2005: Launching and waiting: yes
03:12:24.8 20/12/2005: File not found.
03:12:24.9 20/12/2005: ERRORS DETECTED: EXITING
it looks like you have told gameex to load a program on startup, but it can't find the program, that is why it exits.
Try putting in the correct path to the program you are trying to laucnh
