Sureshot Posted March 8, 2011 Posted March 8, 2011 I ran it in windowed mode and zincgui opens but game does not launch. I read in other forms that I might need a .cfg file but I cant find it on hear. I apologize in advanced if this has been answered in another thread I looked and could not find. Thanks in advance.
fRequEnCy Posted March 8, 2011 Posted March 8, 2011 I ran it in windowed mode and zincgui opens but game does not launch. I read in other forms that I might need a .cfg file but I cant find it on hear. I apologize in advanced if this has been answered in another thread I looked and could not find. Thanks in advance.If running from zincgui then I would think it would run just fine. Is there any error's that pop up? A .cfg file is usually generated by the gui. Have you verified your roms? Please give more detail.
Sureshot Posted March 8, 2011 Author Posted March 8, 2011 no error just opens the gui and that is all. I might have the command and the mappings wrong in GameEX. What are you using? If running from zincgui then I would think it would run just fine. Is there any error's that pop up? A .cfg file is usually generated by the gui. Have you verified your roms? Please give more detail.
fRequEnCy Posted March 8, 2011 Posted March 8, 2011 no error just opens the gui and that is all. I might have the command and the mappings wrong in GameEX. What are you using?Wait!! Are you trying to run zincgui with GameEx? If so then zincgui is a gui for setting up zinc and can run it but does not have a cli so will not just load a game from the command-line with a frontend like GameEx. Solution would be to setup in zinc gui and just load zinc with all the wanted settings.
Sureshot Posted March 8, 2011 Author Posted March 8, 2011 yes.. I tried mapping the zinc.exe and then Rom path/rom name and still wont work form me. Wait!! Are you trying to run zincgui with GameEx? If so then zincgui is a gui for setting up zinc and can run it but does not have a cli so will not just load a game from the command-line with a frontend like GameEx. Solution would be to setup in zinc gui and just load zinc with all the wanted settings.
fRequEnCy Posted March 8, 2011 Posted March 8, 2011 yes.. I tried mapping the zinc.exe and then Rom path/rom name and still wont work form me.zinc requires the rom number, not the rom name. I assume you're trying to run this as a stand-alone emulator? If you want real time support then you can go to the chat room found on top of the screen for support. If not we can trouble shoot from the forums.
Sureshot Posted March 8, 2011 Author Posted March 8, 2011 sure I am in the chat now. and thanks again. zinc requires the rom number, not the rom name. I assume you're trying to run this as a stand-alone emulator? If you want real time support then you can go to the chat room found on top of the screen for support. If not we can trouble shoot from the forums.
Sureshot Posted March 8, 2011 Author Posted March 8, 2011 fRequEnCy Helped resolve my issue. thanks again.
fRequEnCy Posted March 8, 2011 Posted March 8, 2011 fRequEnCy Helped resolve my issue. thanks again.No problem! Enjoy! Marking as [Resolved].
