ive read before people having a few problems with gdi games named track 1 track 2 etc.... having the same track numbers but for different games, well ive experimented and found if you alter the names in the gdi file header ( usual about 1k in size ) to 01,02,03 etc.... then rename the track names to the same 01 02 03 etc... they work then the next game can be 05 06 07 etc.... so all you need to do is put them all in 1 directory and rename them obviously you need to make a note of which file numbers related to what game if you want to delete them but ive tried with a few and it works fine with nulldc v1.0.3 :D need to try in gameex to see if it works.
Hope this helps somebody. SM
Wouldn't putting your roms in subfolders work better and use the roms in folders option.
Well,,, yes Brian it would, but i fancied the hard approach lol :). Also i think somebody mentioned that gameex didnt like it that way. Ive yet to try it though.
Thanks.
