Hey everyone.
I'm using xpadder to try and get the controller to act as a mouse. Everything works dandy outside of GameEx. When I launch a PC game within GameEx, the problem arises.
Using the command line I'll supply later, Xpadder launches and loads up the profile. However, the game will not launch unless I close Xpadder. I just can't figure this one out. If I can get it to work, I wanna use xpadder for VPinMAME too, so I'm hoping this is all something simple I'm missing here.
I noticed another thread where the user ended up using a blank profile to run all the time, but I want xpadder to start and quit only when I want it to as opposed to leaving it running. Any thoughts on what the heck is going wrong here?
I tested these command line arguments outide of GameEx also, and they work just great. Here's what I got:
LaunchBefore=F:\xpadder\Xpadder.exe windowspc /M
LaunchAfter=F:\xpadder\Xpadder.exe /C
Thanks for your help! :)
.:EDIT:. If I do as the original poster suggested, it works. Drat!
Here's what I had to do:
Under Tweaks/Performance, I had to enter my default Xpadder profile:
LaunchOnStartupDontWait=F:\xpadder\Xpadder.exe default /M
LaunchOnExitDontWait=F:\xpadder\Xpadder.exe /C
And in Launch Before/After I just call up the profiles:
LaunchAfter=F:\xpadder\Xpadder.exe default /M
Wonder why it only works this way? :(
