hi guy have installed whdloader and winuae to run amiga games and im getting the following problem
how do i get around press any key i thought a -p was to stop the pause obviously not and how do i not show the winuae loader config screen, once i press start it works ok, also the games seem to run a little slow i have tried x2 which helps but if use custom and go to say 48 its not different.
Any help, tips or advise appreciated.
As always, with respect. SM
I think you may be running in Debug mode. Go to gameex advanced configuration and find your amiga emulator section, and set debug mode to false.
As for the speed, try running your WinUAE in a lower resolution, or using a different renderer such as direct3D.
What do you mean about hiding the WHDloader screen? Have you have registered WHDLoad? It's worth it, I use it in GameEx and my real Amiga. Some WHDLoad hacked games won't run on the unregistered version.
hi yes i ran in debug mode to find out why it wouldn't run i got a black screen and found its waiting for a key to be pressed then it shows the whdload config page when it should run the game,( i need to press start to run the loader, the game then loads fine ) im using a fully legal version which i registered for, for speed i ran in lowres with slightly better speed.
  On 2/28/2011 at 10:16 PM, wubble said:
You've got me there, I'm not sure I've even seen the WHDLoad config page. sorry.
Could you post me your config line in gameex and i`ll try that.
SM
SM
WinUAELoader.exe -mode whdload -rom "[ROMPath]\[RomFile]"
Is that what you meant?
yes and thats what i have, strange it must be something i have set wrong within the WinUAE loader, thanks.
SM
