22:48:29.0 12/22/2005: GameEx: Version 5.31: Starting Log
22:48:29.0 12/22/2005: Operating System Platform: Win32NT
22:48:29.0 12/22/2005: Operating System Name: Windows XP
22:48:29.0 12/22/2005: Operating System Version: 5.1.2600
22:48:29.0 12/22/2005: Checking for versions of .net Framework installed
22:48:29.0 12/22/2005: .net Framework 1.1 Installed
22:48:29.0 12/22/2005: Checking Registration
22:48:29.0 12/22/2005: Running Randomize()
22:48:29.0 12/22/2005: Initialising Video/MNG DLL's
22:48:29.0 12/22/2005: Running Misc startup tasks
22:48:29.0 12/22/2005: Setting Menu types
22:48:29.0 12/22/2005: Opening Configuration File
22:48:29.0 12/22/2005: Getting Configuration Values
22:48:29.0 12/22/2005: Using Theme: Default - Default
22:48:29.0 12/22/2005: Checking for alternate Image Directory for Theme: Default - Default
22:48:29.0 12/22/2005: Text/Language: Custom
22:48:29.0 12/22/2005: Applying Language/Text
22:48:29.1 12/22/2005: Creating Scancodes.txt (List of DirectInput scan codes)
22:48:29.1 12/22/2005: Snap Delay set to: 1
22:48:29.1 12/22/2005: Is Media Center running?
22:48:29.1 12/22/2005: Check Media Center Exit/Start Mode
22:48:29.1 12/22/2005: Media Center Mode 0
22:48:29.1 12/22/2005: Checking for applications to Launch On Startup
22:48:29.2 12/22/2005: Get other settings
22:48:29.2 12/22/2005: Using 2D Animations
22:48:29.2 12/22/2005: Mouse Input is disabled
22:48:29.2 12/22/2005: Desktop set to Hide ICONS and set Background to Black
22:48:29.2 12/22/2005: Backing up Registry Wallpaper Settings
22:48:29.2 12/22/2005: Set: Find emulator artwork on best match basis
22:48:29.2 12/22/2005: Using DirectInput for keyboard input
22:48:29.2 12/22/2005: Launching HideOS.exe
22:48:30.1 12/22/2005: Hiding Taskbar
22:48:30.2 12/22/2005: Start work for Form
22:48:30.2 12/22/2005: Getting Original Screen Size
22:48:30.2 12/22/2005: Loading ICON
22:48:30.2 12/22/2005: Initializing Component
22:48:30.2 12/22/2005: Initialising Bass Audio Library
