ok I have a problem,for some reason I cannot run mame vector games in direct 3d,they run unplayably slow,but if i change to direct draw they run fine.now is there a way to have mame switch to direct draw when running vector games?i know it can be done with mameui,as there is a separate ini for vector games,but not for CL mame
does anyone know how to create a vector.ini in CL mame?
UPDATE: I figured it out after posting (as always!) it seems you can just make a copy of the mame.ini and rename it vector.ini :)
Do i need -videod3d in my gameex mame CL,if it is set in the mame.ini?
As always. I would think after a few times that you would get better at it. :blink:
No switches are needed if ini files are used and enabled.
