It is possible that the image can be the default video (the folder snaps) and picture (folder title) instead of the image (logo or photo) of the emulator (system) because it gets weird in games various language or various discs, only the picture (logo) of the console, as seen below when the cursor is in the blurb or on the title of the game (first line).
This problem only occurs with multi disc games or language.
Would be nice to look like in the third picture, with the cursor in the positions of the title (photo 1 (first line)) and synopses of the game (photo 4).
Thanks for your work!
This would probably be more of a feature request than a bug report. ;)
right, so if the case can move it to session correct please!
although this occurs in this specific version, in previous occurs differently, but also occurs.
It's likely because of the addition to the 'no image found' for all artwork addition Tom made in 11.55. Do you use a default image if one isn't found?
That's why it's defaulting to the system I bet. ;)
but the model should not be without standard image, why he should not use pictures and leave blank.
If I put an image, you will have a different image of the game selecting because it is a standard image to all gaming console, which does not match the details on page one game
I did a test to see what would happen if I use a standard image, the same result as described in my other post if repeated, the only difference I have noticed is when you do not have a video or screenshot for game, that it replaces the system image by standard image, only in list games but not on the details page that continues in the same way with video / snap or not.
