pacsniper Posted February 12, 2011 Share Posted February 12, 2011 anybody know how to configure the emulator Ultra64? The one to run Killer Instinctive been trying to but I dont know specific settings for it.I only want it for Killer Instinct 1 not 2Any help would be appreciated Link to comment Share on other sites More sharing options...
Adultery Posted February 12, 2011 Share Posted February 12, 2011 I use MAME for this too? Looks like I should try it before I say that.... Link to comment Share on other sites More sharing options...
pacsniper Posted February 12, 2011 Author Share Posted February 12, 2011 It runs slow on Mame for me, not on ultra64 though Link to comment Share on other sites More sharing options...
fRequEnCy Posted February 12, 2011 Share Posted February 12, 2011 Maybe this may be of help? Link to comment Share on other sites More sharing options...
pacsniper Posted February 12, 2011 Author Share Posted February 12, 2011 im kind of understanding but at the same time im not.Im trying to set them up but errors come up Link to comment Share on other sites More sharing options...
Krakerman Posted February 12, 2011 Share Posted February 12, 2011 I got Ultra 64 running perfect (Fullscreen) under GameEx Here is how I did it:1) Created two directories one for KI1 and another for KI2 2) Install Ultra 64 in each directory and install your KI1 & KI2 roms in the appropriate directories3) Configure each KI and create a desktop shortcut to each KI1 and KI2 and put them in a directory anywhere you prefer4) Then configured GameEx to run the desktop shortcuts for each KI1 & KI2 Hope that makes sense and helps you along Note: You have to keep KI1 and KI2 in different directories as it won't work if you keep Ultra 64 in one directory. That is why I made one called KI1 and the other KI2 and installed Ultra 64 to each folder. Link to comment Share on other sites More sharing options...
Adultery Posted February 12, 2011 Share Posted February 12, 2011 Is there a noticable benefit to this? I still would need th CHD right? Just pondering doing this myself but haven't tried running it in MAME yet (these games are definately on the short list though!) Link to comment Share on other sites More sharing options...
pacsniper Posted February 13, 2011 Author Share Posted February 13, 2011 I got Ultra 64 running perfect (Fullscreen) under GameEx Here is how I did it:1) Created two directories one for KI1 and another for KI2 2) Install Ultra 64 in each directory and install your KI1 & KI2 roms in the appropriate directories3) Configure each KI and create a desktop shortcut to each KI1 and KI2 and put them in a directory anywhere you prefer4) Then configured GameEx to run the desktop shortcuts for each KI1 & KI2 Hope that makes sense and helps you along Note: You have to keep KI1 and KI2 in different directories as it won't work if you keep Ultra 64 in one directory. That is why I made one called KI1 and the other KI2 and installed Ultra 64 to each folder.Do I put anything else specifically? because im still going to have to click on "Run" for it to start up the game Link to comment Share on other sites More sharing options...
Krakerman Posted February 13, 2011 Share Posted February 13, 2011 No ... In GameEx you setup the emulator roms folder where you have the KI1 and KI2 shortcuts at and the command line will be "[ROMPath]\[RomFile]" it will execute the shortcut without having to click on it.Example (GameEx config):Working path: C:\GameEx\Shortcuts\Ultra 64Roms path: C:\GameEx\Shortcuts\Ultra 64Rom filter: *.lnkCommand Line: "[ROMPath]\[RomFile]"That's it Link to comment Share on other sites More sharing options...
celly Posted February 13, 2011 Share Posted February 13, 2011 I gave up on Ultra64. I aquired the proper CHD's and they run fine now through MAME. Sounds like Krakerman has the fix. Link to comment Share on other sites More sharing options...
Krakerman Posted February 13, 2011 Share Posted February 13, 2011 Btw it also only works with the older version of Ultra 64 as well as the newer version doesn't work correctly. That might be the problem most people run into as you have to use v3.05 of Ultra 64 for it to work right. Why? not sure but that is what I found out. Link to comment Share on other sites More sharing options...
pacsniper Posted February 13, 2011 Author Share Posted February 13, 2011 Im still getting the error messege...dont know why, I have the 3.05 version, im probably just putting the configs wrong Link to comment Share on other sites More sharing options...
fRequEnCy Posted February 13, 2011 Share Posted February 13, 2011 Im still getting the error messege...dont know why, I have the 3.05 version, im probably just putting the configs wrongPlease go to chat room for real-time support. I'll hang out there for awhile. Link to comment Share on other sites More sharing options...
Adultery Posted February 13, 2011 Share Posted February 13, 2011 I gave up on Ultra64. I aquired the proper CHD's and they run fine now through MAME. Sounds like Krakerman has the fix.Already runs like a champ for me in MAME, but thanks anyway. I just had to delete the diff files *doh!* Link to comment Share on other sites More sharing options...
pacsniper Posted February 13, 2011 Author Share Posted February 13, 2011 Please go to chat room for real-time support. I'll hang out there for awhile.have not seen you on in the past hour, ill try again later Link to comment Share on other sites More sharing options...
fRequEnCy Posted February 13, 2011 Share Posted February 13, 2011 have not seen you on in the past hour, ill try again laterJust got back. And i'm talking about the chat room in the link about the forums. Not the one on GameEx.com. Link to comment Share on other sites More sharing options...
pacsniper Posted February 13, 2011 Author Share Posted February 13, 2011 Just got back. And i'm talking about the chat room in the link about the forums. Not the one on GameEx.com.I see, I think im on it now Link to comment Share on other sites More sharing options...
fRequEnCy Posted February 13, 2011 Share Posted February 13, 2011 Resolved! OP had two issues. First issue was that it would run but wouldn't autoload. Fix was to add the "-auto" parameter in the shortcut. Second issue was that emulator was not closing correctly so GameEx had trouble taking back focus. Fix for that was to ensure that the working path and the rom path were the same when dealing with shortcuts. Enjoy pacsniper! Hope you find GameEx to be worth the donation. Link to comment Share on other sites More sharing options...
