Can someone help me please.
I have installed instant sheller,but my problem is that when you start computer it loads into gameex,the first picture says(please wait mame loading)then it comes up with log onto windows,then it has the picture gameex loading please wait.
Is it possible to stop the windows from asking you for a password so that when you turn on computer it just loads straight into gameex without asking you to log onto windows.Thanks.
You can configure Windows XP to automate the logon process if your computer is not part of a domain.
1. Click Start, click Run, and type control userpasswords2.
2. Clear the Users must enter a username and password to use this computer check box.
3. Click Apply.
4. Enter the user name and password you wish to automatically log on with, and then click OK.
5. Click OK again and you're all done.
This feature allows other users to start your computer and use the account that you establish to automatically log on. Enabling auto logon makes your computer more convenient to use, but can pose a security risk.
Or try something here:
http://windowsxp.mvps.org/Autologon.htm
or
http://support.microsoft.com/?kbid=315231
3. Click Apply.
or
