I get this error almost every other time I open GameEx. I re-install it and it runs fine.
18:47:43.0 3/14/2005: GameEx: Version 3.44: Starting Log
18:47:43.1 3/14/2005: Operating System Platform ID: Win32NT
18:47:43.1 3/14/2005: Operating System Version: 5.1
18:47:43.1 3/14/2005: Running Randomize()
18:47:43.1 3/14/2005: Running Misc startup tasks
18:47:43.1 3/14/2005: Hiding Cursor
18:47:43.2 3/14/2005: Opening Configuration File
18:47:43.2 3/14/2005: Getting Configuration Values
18:47:43.2 3/14/2005: Using Theme: Default - Default
18:47:43.2 3/14/2005: Checking for alternate Image Directory for Theme: Default - Default
18:47:43.2 3/14/2005: Applying Language/Text
18:47:43.4 3/14/2005: Launching HideOS.exe
18:47:43.5 3/14/2005: ERRORS DETECTED: EXITING
Please replace GameEx.exe with the one in this zip. then get it to do the same thing and post the log.
Thanks.
GameEx.zip
The first time I cut and pasted the new file and clicked "yes" to overwrite.  Tried it again but deleted the original file first just to make sure.  Still got the same log.  :huh:
Hi, are you getting this problem when launching from MCE?
Yes, it will start to launch and then go to that log. It does seem to be doing it less frequently now though. There is that and also every 2nd or 3rd time I try to run configuration it says it is not a valid win32 application. Don't know if they are related. Both are temporarilly resolved by re-installing.
Hi,
Sound like this is deffinitly not a GameEx issue.
You are experiencing corruption on your hard disk.
There are a few reasons why this could be happening, probably hardware, but here is not the place to ask. Sorry.
Hi,
Bought a new Maxtor 80gb hard drive...same thing. :(
I still think it is not a gameex issue, from what you have said.
Could it be your IDE cable, or possibly a virus or something?
Replaced the IDE cable, same thing:
22:40:10.9 3/23/2005: GameEx: Version 3.44: Starting Log
22:40:10.9 3/23/2005: Operating System Platform ID: Win32NT
22:40:10.9 3/23/2005: Operating System Version: 5.1
22:40:10.9 3/23/2005: Running Randomize()
22:40:10.9 3/23/2005: Running Misc startup tasks
22:40:10.9 3/23/2005: Hiding Cursor
22:40:10.9 3/23/2005: Opening Configuration File
22:40:10.9 3/23/2005: Getting Configuration Values
22:40:10.9 3/23/2005: Using Theme: English - GreenEx Arcade
22:40:10.9 3/23/2005: Checking for alternate Image Directory for Theme: English - GreenEx Arcade
22:40:10.9 3/23/2005: Applying Language/Text
22:40:11.0 3/23/2005: GameEx will display on Secondary Device
22:40:11.1 3/23/2005: Launching HideOS.exe on secondary display
22:40:11.1 3/23/2005: ERRORS DETECTED: EXITING
Guess I'm s.o.l. :(
Guess I'm s.o.l.  :(
Try turning off the secondary display and see if it still does the same thing.
