I just updated to 5.30 and am having some quirky problems after the update.
First, I have a video folder set up for Intro Videos, these are not playing now. It is going straight to the loading screen.
Second, I used to be able to move my trackball over the game titles and I could use that to select the games...now it will not move the cursor bar any more. I have to use the joystick.
Third, when I exit GameEx, my background on the desktop is not reverting back to the original desktop background; it is staying black.
From what I can tell the options for problems 1 and 2 are setup correctly in the admin.
Anyone else experiencing these things?
1. What format are the video files in?
2. Can you plug in a mouse and see if that's working. Are you running at an Arcade Monitor resolution, or turned on ArcadeMode? This disables the mouse.
3. This was a problem in versions before 5.30 but should be fixed now. Could you confirm its deffinitly still happening in 5.30?
Thanks,
Tom
Ok..did some playing around tonight...here's what I've come up with. I just downloaded 5.31.
1. What format are the video files in? Both Files are MPEG
My PC is Dual Purposes in an Arcade Cabinet so a mouse is always connected to the PC. I have tried various themes...some will function and work with the mouse, some will not. I do not have this running in ArcadeMode.
I had been using the Default BlueEx 800X600 for a long time with no problems.
I seems that Default-Default, Default-GameEx, Default-DeepPurple are the ones I tried that will still function properly. Many of the other themes I tried will not work with the mouse any more (highlighting links and using mouse buttons to select)
Even trying these themes, they still are keeping my Desktop black after exiting.
I changed the option of Hide Desktop to NO to stop that problem.
do the files have the .mpeg extenstion or .mpg extension? Make sure there .mpg?
Are they are genuine mpeg 1 files? If not that could be why. I really dont know what could have changed that could stop them playing since random startup videos where introduced. Has anything else changed your end? Do the files play in Windows Media Player?
BlueEx runs in ArcadeMode. The mouse should never have worked. Not sure why it did. If you edit the theme.ini for that theme, and turn off ArcadeMode you should be able to get the mouse to work. If it was working before it was an unintended feature/bug.
Videos are working again..after the 5.31 install.
Mouse issue is resolved with a change in themes.
Any reason why the desktop background won't revert back when exiting GameEx?
2/3 is good going ;)
Dont know about the background at the moment. What OS, patches etc are you using? Do you have any software installed that could affect it. How are you exiting GameEx? Could you also post your log.
I'm running XP Pro SP2
I didn't have this problem before that I can recall before the last couple of GameEx Updates.
Here is my Log...
17:56:43.2 12/21/2005: GameEx: Version 5.31: Starting Log
17:56:43.2 12/21/2005: Operating System Platform: Win32NT
17:56:43.2 12/21/2005: Operating System Name: Windows XP
17:56:43.2 12/21/2005: Operating System Version: 5.1.2600
17:56:43.2 12/21/2005: Checking for versions of .net Framework installed
17:56:43.2 12/21/2005: .net Framework 1.1 Installed
17:56:43.2 12/21/2005: Checking Registration
17:56:43.3 12/21/2005: Running Randomize()
17:56:43.3 12/21/2005: Initialising Video/MNG DLL's
17:56:43.3 12/21/2005: Running Misc startup tasks
17:56:43.3 12/21/2005: Setting Menu types
17:56:43.3 12/21/2005: Opening Configuration File
17:56:43.3 12/21/2005: Getting Configuration Values
17:56:43.3 12/21/2005: Using Theme: Default - GameEx
17:56:43.3 12/21/2005: Checking for alternate Image Directory for Theme: Default - GameEx
17:56:43.3 12/21/2005: Text/Language: English
17:56:43.3 12/21/2005: Applying Language/Text
17:56:43.4 12/21/2005: Creating Scancodes.txt (List of DirectInput scan codes)
17:56:43.4 12/21/2005: Snap Delay set to: 4
17:56:43.4 12/21/2005: Is Media Center running?
17:56:43.4 12/21/2005: Check Media Center Exit/Start Mode
17:56:43.4 12/21/2005: Media Center Mode 0
17:56:43.4 12/21/2005: Checking for applications to Launch On Startup
17:56:43.4 12/21/2005: Get other settings
17:56:43.4 12/21/2005: Using 3D Animations
17:56:43.4 12/21/2005: Desktop set to Hide ICONS and set Background to Black
17:56:43.4 12/21/2005: Backing up Registry Wallpaper Settings
17:56:43.4 12/21/2005: Set: Find emulator artwork on best match basis
17:56:43.5 12/21/2005: SlikStik support enabled
17:56:43.5 12/21/2005: Using DirectInput for keyboard input
17:56:43.5 12/21/2005: Launching HideOS.exe
17:56:44.7 12/21/2005: Hiding Taskbar
17:56:44.7 12/21/2005: Start work for Form
17:56:44.7 12/21/2005: Getting Original Screen Size
17:56:44.7 12/21/2005: Loading ICON
17:56:44.7 12/21/2005: Initializing Component
17:56:45.0 12/21/2005: Initialising Bass Audio Library
17:56:45.3 12/21/2005: Loading default loading screen
17:56:45.5 12/21/2005: Using General Font: HandelGothic BT
17:56:45.5 12/21/2005: Using Title Font: HandelGothic BT
17:56:45.5 12/21/2005: Initialising DirectDraw
17:56:45.5 12/21/2005: Applying GameEx is Loading Image
17:56:45.9 12/21/2005: Creating DirectDraw Device
17:56:45.9 12/21/2005: Using Device: ALL-IN-WONDER 9600 SERIES
17:56:46.1 12/21/2005: Setting Resolution to 800x600 32 bit color
17:56:47.2 12/21/2005: Creating DirectDraw Surfaces
17:56:47.2 12/21/2005: Creating Primary Surface - Full Screen Mode
17:56:47.5 12/21/2005: Creating Back Buffer
17:56:47.5 12/21/2005: Loading graphic surfaces
17:56:47.6 12/21/2005: Creating Surfaces Misc and Dialogs
17:56:47.9 12/21/2005: Creating Surface Volume
17:56:48.0 12/21/2005: Creating Surfaces Arrows
17:56:48.2 12/21/2005: Creating Surfaces GameEXlogo Text
17:56:48.3 12/21/2005: Creating Surfaces Toolbar
17:56:48.7 12/21/2005: Creating Surfaces Backgrounds
17:56:51.1 12/21/2005: Creating Surfaces Toolbar Controls
17:56:51.3 12/21/2005: Creating Surfaces GameEx Logo
17:56:51.3 12/21/2005: Creating Surfaces Home & Exit
17:56:51.4 12/21/2005: Creating Surfaces Snaps
17:56:51.4 12/21/2005: Creating Surfaces Menu and List Bars
17:56:51.6 12/21/2005: Creating Fonts
17:56:51.6 12/21/2005: Creating Menu Font
17:56:52.2 12/21/2005: Creating Game Font
17:56:52.6 12/21/2005: Creating Game Font Standard Size
17:56:52.9 12/21/2005: Creating Font Black
17:56:53.0 12/21/2005: Creating Font Black Small
17:56:53.0 12/21/2005: Creating Game Font Faded
17:56:53.4 12/21/2005: Creating Title Font
17:56:54.3 12/21/2005: Fonts Created Succesfully
17:56:54.3 12/21/2005: Initialising Windows Media Player Component
17:56:54.3 12/21/2005: MAME Path is: E:\Mame32
17:56:54.3 12/21/2005: ZiNc Path is: C:\Emulators\zinc
17:56:54.4 12/21/2005: ZiNc EXE file is: ZiNc.exe
17:56:54.4 12/21/2005: Use ZiNc on. ZiNc.exe will launch PSX games
17:56:54.4 12/21/2005: MAME EXE file is: mame32FXpp.exe
17:56:54.5 12/21/2005: ROM Path is: E:\Mame32\roms
17:56:54.6 12/21/2005: Catver.ini is located at: E:\Mame32\ini\catver.ini
17:56:54.6 12/21/2005: controls.ini is located at: E:\Mame32\ini\controls.ini
17:56:54.6 12/21/2005: History.dat is located at: E:\Mame32\history.dat
17:56:54.8 12/21/2005: nplayers.ini is located at: E:\Mame32\folders\Multiplayer.ini
17:56:54.9 12/21/2005: MAMEinfo.dat is located at: E:\Mame32\mameinfo.dat
17:56:54.9 12/21/2005: Loading Controls.ini map file
17:56:55.0 12/21/2005: Loading Custom Emulators
17:56:55.0 12/21/2005: Loading Emulator 2: Nintendo SNES Games
17:56:55.1 12/21/2005: Loading Emulator 4: Nintendo NES Games
17:56:55.1 12/21/2005: Loading Emulator 5: Atari 2600 Games
17:56:55.4 12/21/2005: Snap Path is: E:\Mame32\snap
17:56:55.5 12/21/2005: AVI Snap Path is: E:\Mame32\AttractVids\ingame
17:56:55.5 12/21/2005: Flyer Path is: E:\Mame32\flyers
17:56:55.5 12/21/2005: Cabinet Path is: E:\Mame32\cabinets
17:56:55.5 12/21/2005: Title Path is: E:\Mame32\titles
17:56:55.5 12/21/2005: Panel Path: Not Found
17:56:55.5 12/21/2005: Icon Path is: C:\Program Files\GameEx\ICONS
17:56:55.5 12/21/2005: Marquee Path is: E:\Mame32\marquees
17:56:55.5 12/21/2005: MAME CMD options: -skip_gameinfo -triplebuffer -nowindow -ddraw -hwstretch -keepaspect -resolution 800x600x0 -joy -lightgun
17:56:55.5 12/21/2005: Attempting to load game list
17:56:55.9 12/21/2005: Running: mame32FXpp.exe -help
17:56:55.9 12/21/2005: Running: E: E:\Mame32\mame32FXpp.exe -help > E:\Mame32\help.txt
17:56:56.6 12/21/2005:
17:56:56.6 12/21/2005: Now Outputing mame32FXpp.exe - Help
17:56:56.6 12/21/2005: --BEGIN--
17:56:56.6 12/21/2005: M.A.M.E. v0.102u4 (Dec 16 2005) - Multiple Arcade Machine Emulator
17:56:56.6 12/21/2005: Copyright © 1997-2005 by Nicola Salmoria and the MAME Team
17:56:56.7 12/21/2005: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
17:56:56.7 12/21/2005: several arcade machines. But hardware is useless without software, so an image
17:56:56.7 12/21/2005: of the ROMs which run on that hardware is required. Such ROMs, like any other
17:56:56.7 12/21/2005: commercial software, are copyrighted material and it is therefore illegal to
17:56:56.7 12/21/2005: use them if you don't own the original arcade machine. Needless to say, ROMs
17:56:56.7 12/21/2005: are not distributed together with MAME. Distribution of MAME together with ROM
17:56:56.7 12/21/2005: images is a violation of copyright law and should be promptly reported to the
17:56:56.7 12/21/2005: authors so that appropriate legal action can be taken.
17:56:56.7 12/21/2005: Usage: MAME gamename [options]
17:56:56.7 12/21/2005: MAME -showusage for a brief list of options
17:56:56.7 12/21/2005: MAME -showconfig for a list of configuration options
17:56:56.7 12/21/2005: MAME -createconfig to create a mame.ini
17:56:56.7 12/21/2005: For usage instructions, please consult the file windows.txt
17:56:56.7 12/21/2005: --END--
17:56:56.7 12/21/2005: Loading last used Game List
17:56:56.7 12/21/2005: Setting Music Volume
17:56:56.7 12/21/2005: Loading WMP Playlists
17:56:59.0 12/21/2005: Creating DirectSound Device
17:56:59.0 12/21/2005: Trying: Primary Sound Driver
17:56:59.0 12/21/2005: Loading Sound Files
17:56:59.1 12/21/2005: DirectSound Device Created Successfully
17:56:59.1 12/21/2005: Creating ICONS
17:56:59.2 12/21/2005: Restoring Cached ICONS from File
17:57:00.4 12/21/2005: Gamepad/Joystick disabled
17:57:00.4 12/21/2005: Initialising DirectInput for Keyboard support
17:57:00.5 12/21/2005: Playing Startup Video
17:57:04.3 12/21/2005: Playing intro sound file
17:57:04.3 12/21/2005: Initializing MCE Remote
17:57:04.3 12/21/2005: Initialization OK! Starting GameEx!
17:57:04.3 12/21/2005: Testing Main Loop Once: Processing Frame
17:57:04.5 12/21/2005: Testing Main Loop Once: Main Loop ran successfully
17:58:02.0 12/21/2005: Running: cmd.exe /c E: E:\Mame32\mame32FXpp.exe 1945kiii -rompath E:\Mame32\roms -skip_gameinfo -triplebuffer -nowindow -ddraw -hwstretch -keepaspect -resolution 800x600x0 -joy -lightgun
17:59:57.0 12/21/2005: Exiting GameEx!
17:59:57.0 12/21/2005: Saving Settings
17:59:57.3 12/21/2005: Writing Game List to disk
18:00:09.1 12/21/2005: Checking for applications to Launch On Exit
I keep my desktop theme as Windows Classic and then after exiting GameEx (which I use both the X in the Program or hit the Exit Button on my CP) it Displays Modified Theme. Not A Big Deal..but would like to see what is causing it at least maybe.
