I have/had nullDC working and booting with mdf, nrg, cdi files etc. but cannot get them to load GDI files. It starts up, goes to the swirl boot logo then exits back to gameex. I'm using r113 with a much older image reader plug in as the newly compiled one doesn't boot. GDI images also don't load in daemon tools. I've tried deleting the daemon tools code as well but rompath/romfile alone doesn't work either.
My config for non GDI images is:
ROMFilter=*.ccd;*.cdi;*.iso;*.mds;*.nrg;*.img;*.gdi;
RomsInFolders=True
WorkingPath=D:\Games\Dreamcast\113
MapKeys=False
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=nullDC_Win32_Release-NoTrace.exe -config ImageReader:DefaultImage="[rompath]/[romfile]"
LaunchBefore=""C:\Program Files\D-Tools\daemon.exe" -mount 0,"[rompath]\[romfile]""
LaunchAfter=""C:\Program Files\D-Tools\daemon.exe" -unmount 0
configFile=[Mapping Off] Exit (ALT+F4)
Any suggestions?
TO
Command=nullDC_Win32_Release-NoTrace.exe -config ImageReader:DefaultImage="[rompath]\[romfile]"
That slash does make a diffrence. If there are other problems this may not address them.
WOW! It worked perfectly on the first try. Thanks!
Edited by Draco1962
This thread is marked as Resolved and is now closed. If the problem re-occurs, please start a new thread.
