does gameex show\store hi scores by itself?or do I still have to use a build of mame with the debugger enabled?
I'm pretty sure you're correct. But it's been a while since I used vanilla MAME though... but the hiscore patch is compiled in so call it an accurate assumption if you will. ;)
Thanks guys.......BTW you were both correct ;)
I tried with my already compiled version of mame and it didnt work,so i compiled a new version with the debugger enabled and success!
Glad you got it up and working. ;)
