I am about to reload my machine. I would like to make sure that I can keep everything that I have done.
I paid for GameEx and would like to make sure that I can still use it after the reload. I just want the settings and the proof of purchase.
I couldn't live without it or go through all that I have custom done with GameEx
Thanks,
Quazl
1. Make a backup of the GameEx directory (usually C:\Program Files\GameEx)
2. Reload your machine
3. Copy your GameEx directory from backup back to C:\Program Files\GameEx
4. Install the latest version (if you like) and it will not overwrite your custom options.
If anything goes wrong, you always have your backup of GameEx anyways, but there should be no problem.
Thanks. that is pretty much what I thought, i just wanted to know for sure.
Again, thanks.
