dukeofarcadia Posted October 14, 2010 Posted October 14, 2010 I want my Mame list to display only games that I actually have roms for, but as of nowit displays all games that you can have for mame (thousands of course). I tried toggling the option"Only existing roms" on and off in the setup wizard but that doesn't do anything?Any Ideas. (I see an option for excluding certain roms, but does that meanI'd actually have to sit and write a list of thousands of games) Even Mamewah which isn't nearly as good makes it simple to display only gamesyou have.Also how do I add new spinning 3d arcade machine things? Where and to what folder?
celly Posted October 14, 2010 Posted October 14, 2010 For your Roms in MAME, try "Update List" and make sure that in the advanced config you have it set to "Only Existing Roms".As for the 3D cabs, you can grab those right off the GameEx website and put them in any folder, just make sure you show the path to them in your MAME confige. Here is a linky for 3D cabs - http://www.gameex.net/Download/MediaandImages.aspx
dukeofarcadia Posted October 14, 2010 Author Posted October 14, 2010 For your Roms in MAME, try "Update List" and make sure that in the advanced config you have it set to "Only Existing Roms".As for the 3D cabs, you can grab those right off the GameEx website and put them in any folder, just make sure you show the path to them in your MAME confige. Here is a linky for 3D cabs - http://www.gameex.net/Download/MediaandImages.aspxThat worked thanks, but where in the config refers to 3d cabs?
dukeofarcadia Posted October 14, 2010 Author Posted October 14, 2010 For your Roms in MAME, try "Update List" and make sure that in the advanced config you have it set to "Only Existing Roms".As for the 3D cabs, you can grab those right off the GameEx website and put them in any folder, just make sure you show the path to them in your MAME confige. Here is a linky for 3D cabs - http://www.gameex.net/Download/MediaandImages.aspxOh and the link is broken for the cabs..
celly Posted October 14, 2010 Posted October 14, 2010 That worked thanks, but where in the config refers to 3d cabs?In either the Advance Config or the Setup Wizard under your MAME. There is a path you can set to show where your 3D cabinet files are. As for the link, I opened it in a new tab (Firefox) and it took me to the GameEx download page. Works fine for me.
fRequEnCy Posted October 14, 2010 Posted October 14, 2010 The download link does appear to be broken. I have reported to Tom! And the setting for the 3d cabinet models can be found in Basic MAME Settings section. The setting is called 3D Cabinet Path where you can point to the path where you saved the files.
fRequEnCy Posted October 14, 2010 Posted October 14, 2010 Link has been fixed! Sorry for the inconvenience.
