I get an error, "Value does not fall within the expected range." I'm not sure what to do with this error since it doesn't tell me anything about the problem. All I know is that it's after "Creating Menu Font" and before it should display "Creating Game Font". This is my first time using this program, and I wouldn't mind knowing what the problem could be. Any ideas?
----- Error Log -----
11:59:50.0 12/10/2005: GameEx: Version 5.25: Starting Log
11:59:50.1 12/10/2005: Operating System Platform: Win32Windows
11:59:50.1 12/10/2005: Operating System Name: Unknown
11:59:50.1 12/10/2005: Operating System Version: 4.10.67766446
11:59:50.1 12/10/2005: Checking for versions of .net Framework installed
11:59:50.1 12/10/2005: .net Framework 1.1 Installed
11:59:50.1 12/10/2005: Checking Registration
11:59:50.1 12/10/2005: Running Randomize()
11:59:50.1 12/10/2005: Initialising Video/MNG DLL's
11:59:50.2 12/10/2005: Running Misc startup tasks
11:59:50.2 12/10/2005: Setting Menu types
11:59:50.2 12/10/2005: Opening Configuration File
11:59:50.2 12/10/2005: Getting Configuration Values
11:59:50.2 12/10/2005: Using Theme: Default - Default
11:59:50.2 12/10/2005: Checking for alternate Image Directory for Theme: Default - Default
11:59:50.3 12/10/2005: Text/Language: English
11:59:50.6 12/10/2005: Applying Language/Text
11:59:51.2 12/10/2005: Creating Scancodes.txt (List of DirectInput scan codes)
11:59:51.3 12/10/2005: Snap Delay set to: 1
11:59:51.3 12/10/2005: Is Media Center running?
11:59:51.3 12/10/2005: Check Media Center Exit/Start Mode
11:59:51.3 12/10/2005: Media Center Mode 2
11:59:51.3 12/10/2005: Checking for applications to Launch On Startup
11:59:51.4 12/10/2005: Get other settings
11:59:51.4 12/10/2005: Using 2D Animations
11:59:51.7 12/10/2005: Desktop set to Hide ICONS and set Background to Black
11:59:51.7 12/10/2005: Backing up Registry Wallpaper Settings
11:59:51.8 12/10/2005: Set: Find emulator artwork on best match basis
11:59:52.0 12/10/2005: Launching HideOS.exe
11:59:53.5 12/10/2005: Hiding Taskbar
11:59:53.5 12/10/2005: Start work for Form
11:59:53.5 12/10/2005: Getting Original Screen Size
11:59:53.5 12/10/2005: Loading ICON
11:59:53.8 12/10/2005: Initializing Component
11:59:54.6 12/10/2005: Initialising Bass Audio Library
11:59:55.1 12/10/2005: Loading default loading screen
11:59:55.6 12/10/2005: Using General Font: Arial
11:59:55.6 12/10/2005: Using Title Font: Arial
11:59:55.7 12/10/2005: Initialising DirectDraw
11:59:56.2 12/10/2005: Creating DirectDraw Device
11:59:56.2 12/10/2005: Using Device: NVIDIA GeForce2 MX/MX 400
11:59:57.6 12/10/2005: Setting Resolution to 640x480 16 bit color
11:59:57.8 12/10/2005: Creating DirectDraw Surfaces
11:59:57.8 12/10/2005: Creating Primary Surface - Full Screen Mode
11:59:57.8 12/10/2005: Creating Back Buffer
11:59:57.8 12/10/2005: Loading graphic surfaces
11:59:57.9 12/10/2005: Creating Surfaces Misc and Dialogs
11:59:58.1 12/10/2005: Creating Surface Volume
11:59:58.1 12/10/2005: Creating Surfaces Arrows
11:59:58.1 12/10/2005: Creating Surfaces GameEXlogo Text
11:59:58.1 12/10/2005: Creating Surfaces Toolbar
11:59:58.2 12/10/2005: Creating Surfaces Backgrounds
11:59:58.4 12/10/2005: Creating Surfaces Toolbar Controls
11:59:58.5 12/10/2005: Creating Surfaces GameEx Logo
11:59:58.5 12/10/2005: Creating Surfaces Home & Exit
11:59:58.5 12/10/2005: Creating Surfaces Snaps
11:59:58.5 12/10/2005: Creating Surfaces Menu and List Bars
11:59:58.8 12/10/2005: Creating Fonts
11:59:58.8 12/10/2005: Creating Menu Font
11:59:59.1 12/10/2005: Value does not fall within the expected range.
12:00:03.3 12/10/2005: ERRORS DETECTED: EXITING
By the look of it, your hardware and software may not be up to the job. Looks like your running windows 98/me with a 5-6 year old graphics card.
I cant offer much advise other than to say upgrade to windows 2000 or XP.
Its hard for me to test windows 98 and ME here, so I may have even changed something in GameEx that makes it not work with those OS's anymore.
Sorry,
Tom.
Sorry,
Tom.
Well, when I upgrade my emulator system (right now, it's a Athlon 800 with 256 mb ram and a Gefore2 MX440), I'll try your program again.
Yes, I'm sorry, but I think your hardware would probably cut it with GameEx. I know others run systems with a spec like that, and say GameEx runs fine. I think your main problem is the version of Windows your using. I have seen issues like this pre windows 2000 with GameEx, when I do my regression testing and I try to make it compatible, but just about all software these days runs much better on 2k or XP. Honestly! If you can beg, borrow or steal a copy of Windows 2000, I think youd be OK actually.
I'm installing XP Home as I'm typing this. I'll let you know how it goes.
On a system with that low spec and running XP, be sure to disable all unnecesary services such as themes, print spooler, fast user switching, error reporting, and secondary login etc. Also make sure you have no extra tray icons loading at start up with "Startup Control Panel".
Once you do all that, GameEx "should" hopefully run full speed.
