I posted mine earlier but I hand named the roms for Vectrex so it likely isn't much help. However the changes are easy to make... does the artwork follow the same naming convention?
If you want to try editing mine, just copy mine from before, paste it in notepad, save it as vectrex.lay and change the rom/artwork names where its needed.
Yes. I noticed that the roms were not in the no-intro format so in this case changes will need to be made. Thanks for that thought. Editing is easy and it's what I'll do when I create it.
The artwork names depend on the source. If the source is from MESS then the artwork has a simple rom name. If the artwork comes from emumovies then they will match the rom name. I guess the best thing to do is just include the artwork and the lay file so that users can just use it instead of making changes. I'll provide the needed files for all known naming convention romsets. I'll take a look at it when I get home to my system. This is still an easy thing to do yet users don't spend the time to do it. LOL. LAZY LAZY. ;)
Hey! I resemble that remark! :D
But yeah I really appreciate your help on this. I've used different .lay files, Adultery's, mine and a few others and edited them the way everyone here says to and still no dice. I've update my MESS to 139 last night thinking it was the 137 that wasn't reading it. Idk. Not a huge big deal though really.
LOL. :P I guess you're implying that you're one of LAZY ones.
No problem. There's too much going on that will complicate things so it's easiest just to provide the files. I will do all the testing to make sure it matches with current version of MESS and current no-intro romset. Will release tomorrow probably because I'm not home yet and still have to go to work tonight. So should be released soon.
