well I really dont know what the deal is,but version 11.20 does not work with either nestopia or bsnes,although they did yesterday.when you click on load this game it flickers and then goes back to the game list screen,all other emu's work fine(fusion,magic engine,mame,mess)also both emulators work fine outside of gameex
Just tested and all is working fine here. Please verify emulator config to verify nothing got overwritten. If so then you can always restore the gameex.ini backup file. If all else fails then please post your emulator config.
I have it setup just like every other that works fine here is the setup for both nestopia(that does not work) and fusion for SMS(which does work)
nfo=Multi system emulator
OLDatZip=
[Emulator_8]
System=Nintendo NES
Category=Console
Emulator=Nestopia
Version=1.40
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Nestopia.7z
RequiredFiles=
Website=http://nestopia.sourceforge.net/
Info=Nintendo NES 8bit emulator
TitleText=Nintendo NES
StartPageName=[Console] Nintendo NES (Nestopia)
StartPageLogo=Nintendo NES
Command=""[APP]\Loaders\Nestopia_Loader.exe" "[ROMPATH]\[ROMFILE]""
RomFilter=
Database=[Console] Nintendo NES
ConfigFile=[Mapping Off] Exit (Process Close)
MapFile=
RomPath=I:\Emulation\Roms\No-Intro\no-intro nes USA
SnapPath=C:\Assets\Nintendo NES\Snaps
TitlePath=C:\Assets\Nintendo NES\Titles
BoxPath=C:\Assets\Nintendo NES\Boxes
CartPath=C:\Assets\Nintendo NES\Cartridges
ManualPath=C:\Assets\Nintendo NES\Manuals
ControlPanelPath=C:\Assets\Nintendo NES\Controls
WorkingPath=D:\nestopia
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=False
RemoveBrackets=True
ShowDesktop=True
Debug=False
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PlaySelectionMusic=False
SelectionMusicFolder=
PCGame=False
GamesIn7Zips=true
PlayInScreenSaver=False
ShowMostPlayed=True
RandomMostPlayed=True
CDCheck=False
CDCheckFile=
[Emulator_9]
Enabled=False
[Emulator_10]
STARTPAGENAME=[Console] Sega Master System (Fusion)
TITLETEXT=Sega Master System
StartPageLogo=Sega Master System
ROMFilter=
RomPath=I:\Emulation\Roms\No-Intro\no-intro sega master system
RomsInFolders=
SnapPath=I:\Emulation\gameex artwork\gameex snaps\sega master system\Sega Master System [Videos][AVI-SQ][EmuMovies 20080908]
TitlePath=I:\Emulation\gameex artwork\gameex snaps\sega master system\Titles
BoxPath=I:\Emulation\gameex artwork\gameex snaps\sega master system\Full Box
CartPath=
ManualPath=
ControlPanelPath=C:\Assets\Sega Master System\Controls
InstructionsPath=
TVAdPath=
MusicPath=
WorkingPath=D:\Fusion364
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=False
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=Fusion.exe -sms -fullscreen "[ROMPATH]\[ROMFILE]"
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=False
DontShowInfo=
PCGame=False
DATABASE=[Console] Sega Master System
UseDbName=False
GamesIn7Zips=True
MergeSets=False
ShowMostPlayed=True
CDCheck=False
CDCheckFile=
CustomArtName1=
CustomArtPath1=
CustomArtName2=
CustomArtPath2=
CustomArtName3=
CustomArtPath3=
System=Sega Master System
Category=Console
Emulator=Fusion
Version=3.63
Rating=
DownloadUrl=http://www.gamesdbase.com/setupwizard/emulators/download/Fusion.7z
RequiredFiles=
Website=http://www.eidolons-inn.net/tiki-index.php?page=Kega
Info=Fusion(formerly known as Kega II and Kega Fusion) is a Sega SG1000, SC3000, Master System, Game Gear, Genesis/Megadrive, SegaCD/MegaCD and 32X emulator
OLDatZip=
[Emulator_11]
Perhaps the issue is because of the command-line:
This is showing that the loader is in your loaders directory of your GameEx install. Is this correct? Because Nestopia doesn't require a loader. The command-line should simply be:
nestopia.exe "[ROMPATH]\[ROMFILE]"
If that's not the problem then please run in debug mode so you can see the output of the window and find out why it won't run.
I dont know how tis is happening...thanks again frequency!
strange thing is it only happened to nes emulators,bsnes and project64 are both the same!
i just noticed that myself,I dont know how this is happening...
Maybe GameEx is entering this information when an update is made? Not sure. LOL. Well there's 2 reports of it now. I'll check with Tom. That's why it's a good idea to compare with your GameEx.ini backup file (GameEx_UpgradeBackup) found in the CONFIG directory of your GameEx install.
ok so now bsnes was doing the same thing so i corrected the command line so now it flickers and then returns to the game select screen,but when i exit out of gameex,the game i chose is running....?very confused.....there are some issues with 11.20no other version crashed my pc,now this version has done so twice
Maybe this?
