Can anyone tell me how to update my gameex to the latest version(currently using 5.10)without deleting my current one and then having to reload all my info.
Do you just download the latest version into your old versions folder or something like that.
Your help is most appreciative.Thanks.
Yes, just install it over the first installation. Just don't use "setup only for games", because then GameEx will change some of the settings with every install. Like "use advanced graphics" or change the theme.
Emph
