Krakerman Posted May 29, 2010 Share Posted May 29, 2010 What is the command line I should use for FBA?UPDATE: Never mind I used the Import emulator feature and got it working:)! Never used that option before. I know I know thanks Tom for putting that feature in GameEx! Link to comment Share on other sites More sharing options...
fRequEnCy Posted May 29, 2010 Share Posted May 29, 2010 What is the command line I should use for FBA?fba.exe [ROM]Path must be setup before using in GameEx so that FBA knows where to launch the roms from. Link to comment Share on other sites More sharing options...
Krakerman Posted May 29, 2010 Author Share Posted May 29, 2010 Thanks fRequEnCy got it before you posted Link to comment Share on other sites More sharing options...
fRequEnCy Posted May 29, 2010 Share Posted May 29, 2010 Thanks fRequEnCy got it before you posted Cool! Glad you got it working. Hopefully next time you'll get it before you post. LOL. Link to comment Share on other sites More sharing options...
Krakerman Posted May 29, 2010 Author Share Posted May 29, 2010 Didn't the old forums have a way to delete your post. I didn't see an option to do it or else I would of just deleted it, but I hear what your saying. Link to comment Share on other sites More sharing options...
fRequEnCy Posted May 29, 2010 Share Posted May 29, 2010 Didn't the old forums have a way to delete your post. I didn't see an option to do it or else I would of just deleted it, but I hear what your saying.Na. Only mods have that power. That's what the forums are for. Can always add "Delete this post" in hopes that a mod will see it and clean it out. But i wouldn't worry about it. Link to comment Share on other sites More sharing options...
