Krakerman Posted May 23, 2010 Share Posted May 23, 2010 I am having troubles with Steam Apps and GameEx. I am able to run Steam games using shortcuts thru GameEx, but the problem lies when I try to close them as it exits back to the desktop and the focus doesn't return to GameEx. I want to keep steam running in the background all the time. Any ideas on how to accomplish this? Link to comment Share on other sites More sharing options...
twotone8 Posted May 24, 2010 Share Posted May 24, 2010 i've been curious about this as well. Link to comment Share on other sites More sharing options...
bkenobi Posted May 24, 2010 Share Posted May 24, 2010 When you run a game that uses a wrapper, GameEx will wait for the launching application to close before it takes focus back. In some cases, this means that GameEx will steal focus from a game shortly after launch (if the launcher closes after launching the game). In other cases, GameEx never takes focus back (in the case where a launcher remains running until it is manually killed...sorta like a service). It sounds like in this case you want to watch a different process than the one that's used to launch a game. If so, you need to look in the Advanced Emulator Config file that you are using and add a different process to the list that GameEx will check. Link to comment Share on other sites More sharing options...
Krakerman Posted May 29, 2010 Author Share Posted May 29, 2010 Well if anyone has any good input on config this let me know cuz I must be missing something because it's not working for me at all Link to comment Share on other sites More sharing options...
Krakerman Posted May 30, 2010 Author Share Posted May 30, 2010 Figured it out!! Created an advanced config file that looks for the processes of the particular game that I am running when it closes then it exits back to GameEx (works great). Thanks for the tips guys. Link to comment Share on other sites More sharing options...
bkenobi Posted May 31, 2010 Share Posted May 31, 2010 Isn't it amazing how much GameEx has built into it? Glad you got it going. Enjoy! Link to comment Share on other sites More sharing options...
