HI,
switched gameex (5.24) to attract mode (just 1/1 video/ games)
When demoing any game I´d like to play a game.
After the set time GAMEEX jumps back to menu/the next video, so you lose your credit and the game aborts.
Any solution for this?
BTW: GAMEEX is an awesome frontend!!!!!
ULI
HI,
ULI
Working fine for me. Are you pressing the credit buttons? Which ones?
Yeah, I saw the threads of this...
To my setup:
I am playing around with MAME and GAMEEX to prepare a MAME CAB that does not exist yet.
I run MAME 0.102
and GAMEEX 5.24
THere are no Controllers hooked up yet - everything is key only.
No Key patchers , no specially "work around drivers" etc.
Regards
ULI
To my setup:
I run MAME 0.102
and GAMEEX 5.24
Regards
ULI
That's strange, please post your gameex log.
Rebootet.
Startet gameex
waitet for attract mode
within the demo of indytemple I inserted coin ("5") and started game ("1").
After a minute? (attract is set to one minute) Gameex returned to Menu.
LOG:
16:45:45.4 30.11.2005: GameEx: Version 5.24: Starting Log
16:45:45.5 30.11.2005: Operating System Platform: Win32NT
16:45:45.5 30.11.2005: Operating System Name: Windows XP
16:45:45.5 30.11.2005: Operating System Version: 5.1.2600
16:45:45.5 30.11.2005: Checking Registration
16:45:45.5 30.11.2005: Running Randomize()
16:45:45.5 30.11.2005: Initialising Video/MNG DLL's
16:45:45.5 30.11.2005: Running Misc startup tasks
16:45:45.5 30.11.2005: Setting Menu types
16:45:45.5 30.11.2005: Opening Configuration File
16:45:45.5 30.11.2005: Getting Configuration Values
16:45:45.5 30.11.2005: Using Theme: Default - Galaxian
16:45:45.5 30.11.2005: Checking for alternate Image Directory for Theme: Default - Galaxian
16:45:45.5 30.11.2005: Text/Language: German
16:45:45.5 30.11.2005: Applying Language/Text
16:45:45.5 30.11.2005: Creating Scancodes.txt (List of DirectInput scan codes)
16:45:45.5 30.11.2005: Snap Delay set to: 1
16:45:45.5 30.11.2005: Is Media Center running?
16:45:45.5 30.11.2005: Check Media Center Exit/Start Mode
16:45:45.5 30.11.2005: Media Center Mode 2
16:45:45.5 30.11.2005: Checking for applications to Launch On Startup
16:45:45.5 30.11.2005: Get other settings
16:45:45.5 30.11.2005: Using 2D Animations
16:45:45.5 30.11.2005: Desktop set to Hide ICONS and set Background to Black
16:45:45.5 30.11.2005: Backing up Registry Wallpaper Settings
16:45:45.6 30.11.2005: Launching HideOS.exe
16:45:46.7 30.11.2005: Hiding Taskbar
16:45:46.7 30.11.2005: Start work for Form
16:45:46.7 30.11.2005: Getting Original Screen Size
16:45:46.8 30.11.2005: Loading ICON
16:45:47.0 30.11.2005: Initializing Component
16:45:47.1 30.11.2005: Initialising Bass Audio Library
16:45:47.4 30.11.2005: Loading default loading screen
16:45:47.4 30.11.2005: Using General Font: HandelGothic BT
16:45:47.4 30.11.2005: Using Title Font: HandelGothic BT
16:45:47.4 30.11.2005: Initialising DirectDraw
16:45:47.5 30.11.2005: Creating DirectDraw Device
16:45:47.5 30.11.2005: Using Device: MOBILITY RADEON 9200
16:45:47.5 30.11.2005: Setting Resolution to 800x600 32 bit color
16:45:48.4 30.11.2005: Creating DirectDraw Surfaces
16:45:48.4 30.11.2005: Creating Primary Surface - Full Screen Mode
16:45:48.5 30.11.2005: Creating Back Buffer
16:45:48.5 30.11.2005: Loading graphic surfaces
16:45:48.5 30.11.2005: Creating Surfaces Misc and Dialogs
16:45:48.5 30.11.2005: Creating Surface Volume
16:45:48.5 30.11.2005: Creating Surfaces Arrows
16:45:48.6 30.11.2005: Creating Surfaces GameEXlogo Text
16:45:48.6 30.11.2005: Creating Surfaces Toolbar
16:45:48.6 30.11.2005: Creating Surfaces Backgrounds
16:45:48.9 30.11.2005: Creating Surfaces Toolbar Controls
16:45:48.9 30.11.2005: Creating Surfaces GameEx Logo
16:45:49.0 30.11.2005: Creating Surfaces Home & Exit
16:45:49.0 30.11.2005: Creating Surfaces Snaps
16:45:49.0 30.11.2005: Creating Surfaces Menu and List Bars
16:45:49.0 30.11.2005: Creating Fonts
16:45:49.0 30.11.2005: Creating Menu Font
16:45:49.4 30.11.2005: Creating Game Font
16:45:49.7 30.11.2005: Creating Game Font Standard Size
16:45:50.0 30.11.2005: Creating Font Black
16:45:50.1 30.11.2005: Creating Font Black Small
16:45:50.1 30.11.2005: Creating Game Font Faded
16:45:50.5 30.11.2005: Creating Title Font
16:45:51.2 30.11.2005: Fonts Created Succesfully
16:46:16.3 30.11.2005: MAME Path is: D:\mame
16:46:16.3 30.11.2005: MAME EXE file is: mame.exe
16:46:16.3 30.11.2005: ROM Path is: D:\mame\roms
16:46:16.3 30.11.2005: Catver.ini is located at: C:\Programme\GameEx\DATA\catver.ini
16:46:16.3 30.11.2005: controls.ini is located at: C:\Programme\GameEx\data\controls.ini
16:46:16.3 30.11.2005: History.dat is located at: C:\Programme\GameEx\DATA\history.dat
16:46:16.3 30.11.2005: nplayers.ini is located at: C:\Programme\GameEx\DATA\nplayers.ini
16:46:16.3 30.11.2005: MAMEinfo.dat is located at: C:\Programme\GameEx\DATA\mameinfo.dat
16:46:16.3 30.11.2005: Loading Controls.ini map file
16:46:16.4 30.11.2005: Loading Custom Emulators
16:46:16.7 30.11.2005: Snap Path: Not Found
16:46:16.7 30.11.2005: AVI Snap Path: Not Found
16:46:16.7 30.11.2005: Flyer Path: Not Found
16:46:16.7 30.11.2005: Cabinet Path: Not Found
16:46:16.7 30.11.2005: Title Path: Not Found
16:46:16.7 30.11.2005: Panel Path: Not Found
16:46:16.7 30.11.2005: Icon Path: Not Found
16:46:16.7 30.11.2005: Marquee Path: Not Found
16:46:16.7 30.11.2005: MAME CMD options: -triplebuffer -nowindow -joy
16:46:16.7 30.11.2005: Attempting to load game list
16:46:16.7 30.11.2005: Loading last used Game List
16:46:16.7 30.11.2005: Cannot Load Play List. Check Path and filename
16:46:16.7 30.11.2005: Sound Disabled
16:46:16.7 30.11.2005: Initialising DirectInput for Gamepad support
16:46:16.7 30.11.2005: Unable to create a joystick device
16:46:16.7 30.11.2005: Initializing MCE Remote
16:46:16.8 30.11.2005: Initialization OK! Starting GameEx!
16:46:16.8 30.11.2005: Testing Main Loop Once: Processing Frame
16:46:16.9 30.11.2005: Testing Main Loop Once: Main Loop ran successfully
16:46:30.7 30.11.2005: Running: cmd.exe /c D: D:\mame\mame.exe brubber -rompath D:\mame\roms -triplebuffer -nowindow -joy
16:49:25.4 30.11.2005: Starting Attract Mode
16:49:25.4 30.11.2005: Running: cmd.exe /c D: D:\mame\mame.exe indytemp -rompath D:\mame\roms -triplebuffer -nowindow -joy
16:50:08.2 30.11.2005: Exiting GameEx!
16:50:08.2 30.11.2005: Saving Settings
16:50:08.3 30.11.2005: Writing Game List to disk
16:50:10.4 30.11.2005: Checking for applications to Launch On Exit
Hi Tom,
thats funny: installed gamex on my office desktop pc and tried to configure it the same way (though it has different paths of course).
(both with win xp pro)
Gotcha... playing games from "attract mode" works fine.
So probably we´ll never find out whats going on exactly...
Anyway: is there a way (feature request) that after playing a game (lets say 3-4 minutes) GAMEEX Menu starts again?
Best regards!
ULI
