Running 5.24. Daphne worked sporadically in 5.19 for me. Now in 5.24 it won't launch at all. Using .NET Framework 1.1 and use the recommended framefile reference as below:
vldp -fullscreen -x 640 -y 480 -nohwaccel (Global Setting)
-framefile c:\Daphne\mpeg2\ace.txt (Game Launch Example)
Anyone have anything different? GameEx tries to launch the game but then freezes at a black screen and I need to ctrl-alt-del to pull up task manager to close Daphne manually.
FYI, my mame roms are on E: USB drive along with Mame32, GameEx and Daphne + Roms runs on c: as referenced above.
Thoughts?
TIme
It's (sort of) working here for me. Games load but my directional controls are dead. Strange becuase my 1p, 2p, Coin 1, coin2 and "button1" are working just fine. But games are loading for me on 5.24.
What is the Daphne error log saying?
Strange. First try to load Daphne through GameEx always hangs...
CTrl, Alt, Del and Shut down Daphne manually. Now on relaunch through GameEx all games load fine. This has to be done once and all is well unless computer is rebooted.
That's my fix for now. Again, games load on first try through Daphne loader. Second try with GameEx...
Time
Time
Could you guys with loading issues with Daphne post the Daphne and GameEx logs please?
Also confirm, are you using Arcade Ambiance?
Thanks.
Tom..
Arcade ambience is ON...
Daphne log:
--DAPHNE version 0.99.7
--Command line is: Daphne.exe lair vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile c:\Daphne\mpeg2\lair.txt
--CPU : GenuineIntel 2650 MHz || Mem : 1024 megs
--OS : Windows XP/.NET || Video : RADEON 9000 SERIES
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 80000000
Initializing sound system ...
No joysticks detected
Loading compressed ROM image dl_f2_u1.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u2.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u3.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u4.bin...8192 bytes read.
Framefile parse succeeded. Video/Audio directory is: c:/Daphne/mpeg2/./lair/
YUV overlay is done in software (ie unaccelerated).
Booting ROM ...
Play
LDP : disc is already playing, play command ignored
Play
Display disable received
Search to 323 received - [25] Attract Mode, Sequence 0 Attract Mode
Play
Gameex log:
14:28:07.5 11/29/2005: GameEx: Version 5.23: Starting Log
14:28:07.6 11/29/2005: Operating System Platform: Win32NT
14:28:07.6 11/29/2005: Operating System Name: Windows XP
14:28:07.6 11/29/2005: Operating System Version: 5.1.2600
14:28:07.6 11/29/2005: Checking Registration
14:28:07.6 11/29/2005: Running Randomize()
14:28:07.7 11/29/2005: Initialising Video/MNG DLL's
14:28:08.1 11/29/2005: Running Misc startup tasks
14:28:08.1 11/29/2005: Setting Menu types
14:28:08.1 11/29/2005: Opening Configuration File
14:28:08.1 11/29/2005: Getting Configuration Values
14:28:08.3 11/29/2005: Using Theme: Default - Galaxian
14:28:08.3 11/29/2005: Checking for alternate Image Directory for Theme: Default - Galaxian
14:28:08.3 11/29/2005: Text/Language: Custom
14:28:08.3 11/29/2005: Applying Language/Text
14:28:08.4 11/29/2005: Creating Scancodes.txt (List of DirectInput scan codes)
14:28:08.5 11/29/2005: Snap Delay set to: 1
14:28:08.5 11/29/2005: Is Media Center running?
14:28:08.5 11/29/2005: Check Media Center Exit/Start Mode
14:28:08.5 11/29/2005: Media Center Mode 2
14:28:08.5 11/29/2005: Checking for applications to Launch On Startup
14:28:08.5 11/29/2005: Get other settings
14:28:08.5 11/29/2005: Using 2D Animations
14:28:08.5 11/29/2005: Desktop set to Hide ICONS and set Background to Black
14:28:08.5 11/29/2005: Backing up Registry Wallpaper Settings
14:28:08.6 11/29/2005: Launching HideOS.exe
14:28:10.7 11/29/2005: Hiding Taskbar
14:28:10.7 11/29/2005: Start work for Form
14:28:10.7 11/29/2005: Getting Original Screen Size
14:28:10.7 11/29/2005: Loading ICON
14:28:10.7 11/29/2005: Initializing Component
14:28:10.9 11/29/2005: Initialising Bass Audio Library
14:28:11.2 11/29/2005: Loading default loading screen
14:28:11.3 11/29/2005: Using General Font: HandelGothic BT
14:28:11.3 11/29/2005: Using Title Font: HandelGothic BT
14:28:11.3 11/29/2005: Initialising DirectDraw
14:28:11.3 11/29/2005: Applying GameEx is Loading Image
14:28:11.5 11/29/2005: Creating DirectDraw Device
14:28:11.5 11/29/2005: Using Device: RADEON 9000 SERIES
14:28:11.5 11/29/2005: Setting Resolution to 800x600 32 bit color
14:28:12.2 11/29/2005: Creating DirectDraw Surfaces
14:28:12.2 11/29/2005: Creating Primary Surface - Full Screen Mode
14:28:12.3 11/29/2005: Creating Back Buffer
14:28:12.3 11/29/2005: Loading graphic surfaces
14:28:12.3 11/29/2005: Creating Surfaces Misc and Dialogs
14:28:12.5 11/29/2005: Creating Surface Volume
14:28:12.5 11/29/2005: Creating Surfaces Arrows
14:28:12.5 11/29/2005: Creating Surfaces GameEXlogo Text
14:28:12.5 11/29/2005: Creating Surfaces Toolbar
14:28:12.6 11/29/2005: Creating Surfaces Backgrounds
14:28:13.2 11/29/2005: Creating Surfaces Toolbar Controls
14:28:13.3 11/29/2005: Creating Surfaces GameEx Logo
14:28:13.3 11/29/2005: Creating Surfaces Home & Exit
14:28:13.3 11/29/2005: Creating Surfaces Snaps
14:28:13.3 11/29/2005: Creating Surfaces Menu and List Bars
14:28:13.6 11/29/2005: Creating Fonts
14:28:13.6 11/29/2005: Creating Menu Font
14:28:14.2 11/29/2005: Creating Game Font
14:28:14.6 11/29/2005: Creating Game Font Standard Size
14:28:14.9 11/29/2005: Creating Font Black
14:28:15.0 11/29/2005: Creating Font Black Small
14:28:15.0 11/29/2005: Creating Game Font Faded
14:28:15.4 11/29/2005: Creating Title Font
14:28:16.1 11/29/2005: Fonts Created Succesfully
14:28:16.2 11/29/2005: Initialising Windows Media Player Component
14:28:16.5 11/29/2005: MAME Path is: E:\Mame32
14:28:16.5 11/29/2005: daphne Path is: C:\Daphne
14:28:16.5 11/29/2005: daphne EXE file is: Daphne.exe
14:28:16.6 11/29/2005: Use daphne on. Daphne.exe will launch games
14:28:16.6 11/29/2005: MAME EXE file is: Mame32.exe
14:28:16.6 11/29/2005: ROM Path is: E:\Mame32\roms
14:28:16.6 11/29/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
14:28:16.6 11/29/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
14:28:16.6 11/29/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
14:28:16.6 11/29/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
14:28:16.6 11/29/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
14:28:16.6 11/29/2005: Loading Controls.ini map file
14:28:16.7 11/29/2005: Loading Custom Emulators
14:28:16.9 11/29/2005: Snap Path is: E:\Mame32\snap
14:28:16.9 11/29/2005: AVI Snap Path: Not Found
14:28:17.0 11/29/2005: Flyer Path is: E:\Mame32\flyers
14:28:17.0 11/29/2005: Cabinet Path is: E:\Mame32\cabinets
14:28:17.0 11/29/2005: Title Path is: E:\Mame32\titles
14:28:17.0 11/29/2005: Panel Path is: E:\Mame32\cpanel
14:28:17.0 11/29/2005: Icon Path is: E:\Mame32\icons
14:28:17.0 11/29/2005: Marquee Path is: E:\Mame32\marquees
14:28:17.0 11/29/2005: MAME CMD options: -triplebuffer -nowindow -joy
14:28:17.1 11/29/2005: Attempting to load game list
14:28:17.3 11/29/2005: Loading last used Game List
14:28:21.1 11/29/2005: Creating DirectSound Device
14:28:21.1 11/29/2005: Trying: Primary Sound Driver
14:28:21.1 11/29/2005: Loading Sound Files
14:28:21.2 11/29/2005: DirectSound Device Created Successfully
14:28:21.2 11/29/2005: Creating ICONS
14:28:21.2 11/29/2005: Restoring Cached ICONS from File
14:28:25.6 11/29/2005: Initialising DirectInput for Gamepad support
14:28:25.7 11/29/2005: Unable to create a joystick device
14:28:25.7 11/29/2005: Playing intro sound file
14:28:25.7 11/29/2005: Initializing MCE Remote
14:28:25.8 11/29/2005: Initialization OK! Starting GameEx!
14:28:25.8 11/29/2005: Testing Main Loop Once: Processing Frame
14:28:26.0 11/29/2005: Testing Main Loop Once: Main Loop ran successfully
14:29:18.2 11/29/2005: Running: cmd.exe /c C: C:\Daphne\Daphne.exe lair vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile c:\Daphne\mpeg2\lair.txt
14:31:03.9 11/29/2005: Exiting GameEx!
14:31:03.9 11/29/2005: Saving Settings
14:31:03.9 11/29/2005: Writing Game List to disk
14:31:06.4 11/29/2005: Checking for applications to Launch On Exit
Tom,
That was the log after the errors.  Again, first try it freezes.  Shut down Daphne manually and rerun through GameEx and all well.
Time
Is daphne completly hung, no sound at all.
If you exit GameEx and restart, works?
Is gameex set to load on startup on your machine? Sounds like windows may not be initialising certain stuff in time. Are you using any special audio or video software or tray apps? Have you changed any windows services?
GameEx IS setup to load automatically on startup
No special apps. Mame 32, GameEx, and Daphne only things on machine
Mame32 loads on E USB drive, GameEx and Daphne load on C
WinXP SP2 with all latest updates
Daphne goes black screen when loached through GameEx on first try. Kill Daphne, GameEx resumes, relaunch a Daphne title through GameEx all well. Never hangs again.
Time
