Hi, i have a low Resolution Arcade monitor. It only support 640*288 max.
I see the menu OK but i cann´t see some games. Example 1942.
I´ve generated INI with AVRES but i don´t now witch is the config option in GAMEEX. Where must i config it?
Before i used MAMEWAH and it works fine with the INI files but i cann´t make it wotk on Gameex
thks
Jose
thks
Jose
Assuming MAME is setup correctly it should automatically use the ini files you created. The created ini files are used by MAME not GameEx. To use the built in ArcadeVGA support in GameEx instead though just enable it in the configuration application. Set GameEx to use the resolution 640X288 also.
Some games not showing sounds like it is a different problem entirely, check all the settings unders Advanced MAME settings and update the list, check things such as the filters and verify. You can also force GameEx to include certain games.
Have another look then post back.
Cheers
