DesktopMAME
DesktopMAME is a windows wallpaper changer
It allows you to change your windows wallpaper automatically every amount of minutes you specify and display a collage of MAME related artwork.
Simply download and follow the simple install, then run the configuration utility to set your Snap, Flyer and Marquee paths, set how often you wish the application to change the desktop wallpaper then run it.
http://tomspeirs.com/desktopmame
Tom,
Very nice utility. I really appreciate what you are doing. It seems that you are able to find all kind of new things. Where other developers just keep stuck to improvement of their frontend, you really rock with your nice utilities.
By the way, I posted this news also on the Mameworld news forum. Hope you don't mind.
Oeps, just saw you did post it yourself. I deleted my post over there.
Tom,
Thanks for the feedback guys, yes I am kind of proud of the DesktopMAME, I have it permantly running on my MCE PC :D
