26th November 2005
- GameEx 5.23
  • OK, the new working of show
    desktop was not working for everyone so I've
    reverted back an tried a new approach.
  • There's a new display setting
    to hide the desktop. With this setting on when in
    full screen mode GameEx will hide the desktop
    ICONS, and set the Wallpaper to tiled black. This
    is a much better approach, and assuming you have
    no other apps open, the transition to apps and
    emulators that need the show desktop setting
    should be normally seamless.
  • I also modified the wait
    before keys setting to be used even if no keys are
    specified, as HideOS.exe is not closed until this
    timer has passed.
  • Therefore to load Visual
    Pinball seamlessly set this setting to about 8000
    (8 seconds)
  • Fixed: text and layout now
    resizes correctly when going from windowed to full
    screen.
  • Fixed: Snap and background
    videos now show and reload when changing Windowed/
    Full screen.
  • Just to clear up things about
    .net framework 2.0. GameEx does not use version
    2.0 (yet). You should install 1.1.
  • Microsoft seem to be creating
    a bit of a dll hell situation with the different
    versions. If you have version 1.0 installed,
    Windows Update will give you the option to
    download 2.0 only. Where GameEx runs on 1.1 with
    support for 1.0
  •  .net 2.0 if installed
    broke GameEx previously even though GameEx will
    only use 1.0 or 1.1. The update was to fix this
    issue and make GameEx work if you happen to
    download it from Windows Update or use it for
    other apps. Installing .net framework 2.0 will not
    improve or affect anything in GameEx in any way
    (at the moment)
  • Everyone finds this very
    confusing, and MS does not seem to attempt to make
    this better understood. They often don't tell you
    at face value even if your using a beta version,
    or provide good versioning information for Beta
    versions, but still encourage you to download
    them.
  • I do plan on starting to use
    Visual Studio 2005, and I will be upgrading GameEx
    to use Visual Studio 2005 and .net framework 2.0
    in the future once I have some reserve cash to buy
    the development suite, and I see some benefit in
    upgrading.
Hi Tom,
Version 5.23 is working great so far. Is it possible to change the time GameEx hides the desktop with that new display setting? Visual Pinmame now just needs a hair longer to be hidden before its finished loading a table. :)
Thanks for all the recent updates! Oh for some reason I thought you were here in the US :)
BR
Hi Tom,
BR
If you set Wait Before keys to something like 8000 it should hide the startup of it,
No worries, it's normal.
Hi Tom,
BR
i installed the Version 5.23 with my mame32 /Mame32v.102 and everything loaded up nice but my desktop screen shifted when i booted up the new version of gameex what did i do wrong how do i fix this
Your desktop shifted? What version of GameEx are you upgrading from? I have been upgrading my mame32 and GameEx with no graphic issues since 5.11. Are you talking about all you desktop icons and such?
BR
Please stop this behaviour, your sending PM's to me and posting at the same time, and also double posting, your trying my patience. Are you over 16 (as specified in the forum rules)? I can only put your rudeness down to you being very young.
Galaxian Theme = Best Theme to Date for Mame.
Thank you.  Thank you.  Thank you!!!
Time
I really can't take credit for it, it was by HeadKaze, who seems to be a very talented chap in all areas of IT.
Thanks to both. Excellent integration. You ease of install Tom is what makes GameEx great. Front ends that are a nitemare to config make things frustrating.
My System 1 Cab is finally stripped and the Mame machine running GameEx will take place of the old Indiana Jones guts!!
Picture to follow on the cabinets page...
Time
hmm 5.22 the way you were hiding the desktop seemed fine to me, i'll try this later :/ maybe you need option for desktop hide method or something.
update: ok 5.23 seems ok aswell for me, except two things:
1) its possible to leave your desktop black - not the worst thing in the world, but something i saw.
update: yeah still black after changing desktop colour.. what's up with that?!
2) having problems transitioning in and out of Fusion (Sega emulator). anyone else seeing this? (stuck on black screen, fusion running and using lots of cpu time). not sure if this is new or gameex problem because havent used fusion in a while. have to force kill fusion.exe, then gameex comes back fine. (showdesktop=false, this def used to work ok a few months ago).
I didn't know you had to send keys for Visual Pinball? What keys need to be sent? If you were supposed to send keys, then I think we have found the problem a few of us were having. Perhaps hiding the icons and wallpaper was an unessessary move. I think the older method of hiding was better than hiding the icons and wallpaper anyway.
Also, found a small bug on this release, after launching GameEx and exiting it changes my wallpaper from being stretched to tiled.
1.my desktop shifted? installed the Version 5.23 of GameEx mame32 /Mame32v.102 is what im sorry about sending you PM's dbbl and posting at the same time, your trying my patience. dude im 35 kind gets iretating when know one answers you ill show you my desktop what it did when i clicked on Version 5.23 of GameEx
2. where do i find daphne the emulator at and what version do i need to get to play these laserdisk roms on my computer
3. the daphne emulator i downloaded is
Sega CD Roms will that work on the daphne emaultor
btw sorry TSpeirs and other fellow member for pm you and dbbl posting will not happen again
do you see how my desktop shifted how do i fix that
[email protected]
.. etc..
1. The "shifted screen" you describe is simply the wallpaper going from stretched to tiled, as I have already stated in the post you quoted above. Tom is now aware of this, so you don't need to post about it again in obnoxious bold blue text. :angry:
2. Use Google, we are not an Internet service which helps people learn how to use ordinary functions of a computer system.
3. How do we know what's on your "Sega CD Roms" disc??
1. sorry
2. it asked me you are about to start daphne without a laser disc player or MEPEG
configured how do i fix that look on the pictures
[email protected]
Movieman,
You should check with RomCenter or daphne-emu.com. This forum is only for GameEx support. Your problem is with the config of Daphne which is not very easy to do.
Tiptonware.com offers a automatic configutaiton of Daphne so you might try his set as it is plug and play.
Time
1. sorry well i went to romcenter and i pay 6.99 a month for these roms that is why i asked is everythig set up right for the daphne emulator
[email protected]
5.23 Bug.
Tom,
Arcade Ambience plays in the background when you go to your jukebox!!! MP3's and Ambience play together. Not what you intended Im sure. Ambience should go to sleep when in Jukebox and come back upon exit of Jukebox.
Time
Tom, now that Visual Mame is launching great, can you do anything about exiting? "The Quit?" dialog box appears briefly when escape is pressed. The visual pinball CAD screen shows for a brienf moment also.
for snes the emulator that im using is znes ver. 1.42 the emulator loaded up find on gameex no problem but it had a trouble finding the roms tho i have pictures for you guys to look at maybe you can help
[email protected]
for snes the emulator that im using is znes ver. 1.42 the emulator loaded up find on gameex no problem but it had a trouble finding the roms tho i have pictures for you guys to look at maybe you can help  here is my log below form gameex
21:32:15.5  11/26/2005:  GameEx: Version 5.23: Starting Log
21:32:15.5  11/26/2005:  Operating System Platform: Win32NT
21:32:15.5  11/26/2005:  Operating System Name: Windows XP
21:32:15.5  11/26/2005:  Operating System Version: 5.1.2600
21:32:15.5  11/26/2005:  Checking Registration
21:32:15.5  11/26/2005:  Running Randomize()
21:32:15.5  11/26/2005:  Initialising Video/MNG DLL's
21:32:15.6  11/26/2005:  Running Misc startup tasks
21:32:15.6  11/26/2005:  Setting Menu types
21:32:15.6  11/26/2005:  Opening Configuration File
21:32:15.6  11/26/2005:  Getting Configuration Values
21:32:15.6  11/26/2005:  Using Theme: Default - Default
21:32:15.6  11/26/2005:  Checking for alternate Image Directory for Theme: Default - Default
21:32:15.7  11/26/2005:  Text/Language: English
21:32:15.7  11/26/2005:  Applying Language/Text
21:32:15.8  11/26/2005:  Custom Keyboard Input enabled: Getting custom codes
21:32:15.8  11/26/2005:  Creating Scancodes.txt (List of DirectInput scan codes)
21:32:15.9  11/26/2005:  Snap Delay set to: 3
21:32:15.9  11/26/2005:  Is Media Center running?
21:32:15.9  11/26/2005:  Check Media Center Exit/Start Mode
21:32:16.0  11/26/2005:  Media Center Mode 2
21:32:16.0  11/26/2005:  Checking for applications to Launch On Startup
21:32:16.0  11/26/2005:  Get other settings
21:32:16.0  11/26/2005:  Using 2D Animations
21:32:16.1  11/26/2005:  Desktop set to Hide ICONS and set Background to Black
21:32:16.1  11/26/2005:  Backing up Registry Wallpaper Settings
21:32:16.2  11/26/2005:  Using DirectInput for keyboard input
21:32:16.2  11/26/2005:  Start work for Form
21:32:16.2  11/26/2005:  Getting Original Screen Size
21:32:16.3  11/26/2005:  Loading ICON
21:32:16.4  11/26/2005:  Initializing Component
21:32:16.5  11/26/2005:  Initialising Bass Audio Library
21:32:17.2  11/26/2005:  Loading default loading screen
21:32:17.6  11/26/2005:  Using General Font: Trebuchet MS
21:32:17.6  11/26/2005:  Using Title Font: Trebuchet MS
21:32:17.6  11/26/2005:  Initialising DirectDraw
21:32:18.5  11/26/2005:  Creating DirectDraw Device
21:32:19.5  11/26/2005:  Creating DirectDraw Surfaces
21:32:19.6  11/26/2005:  Creating Primary Surface - Windowed Mode
21:32:19.6  11/26/2005:  Creating Back Buffer
21:32:19.7  11/26/2005:  Loading graphic surfaces
21:32:19.8  11/26/2005:  Creating Surfaces Misc and Dialogs
21:32:20.1  11/26/2005:  Creating Surface Volume
21:32:20.2  11/26/2005:  Creating Surfaces Arrows
21:32:20.3  11/26/2005:  Creating Surfaces GameEXlogo Text
21:32:20.3  11/26/2005:  Creating Surfaces Toolbar
21:32:20.6  11/26/2005:  Creating Surfaces Backgrounds
21:32:21.4  11/26/2005:  Creating Surfaces Toolbar Controls
21:32:21.5  11/26/2005:  Creating Surfaces GameEx Logo
21:32:21.6  11/26/2005:  Creating Surfaces Home & Exit
21:32:21.8  11/26/2005:  Creating Surfaces Snaps
21:32:21.8  11/26/2005:  Creating Surfaces Menu and List Bars
21:32:22.2  11/26/2005:  Creating Fonts
21:32:22.3  11/26/2005:  Creating Menu Font
21:32:22.9  11/26/2005:  Creating Game Font
21:32:23.2  11/26/2005:  Creating Game Font Standard Size
21:32:23.8  11/26/2005:  Creating Font Black
21:32:24.0  11/26/2005:  Creating Font Black Small
21:32:24.1  11/26/2005:  Creating Game Font Faded
21:32:24.3  11/26/2005:  Creating Title Font
21:32:25.3  11/26/2005:  Fonts Created Succesfully
21:32:50.8  11/26/2005:  Initialising Windows Media Player Component
21:32:52.1  11/26/2005:  MAME Path is: C:\mame32
21:32:52.1  11/26/2005:  MAME EXE file is: Mame32.exe
21:32:52.2  11/26/2005:  ROM Path is: C:\mame32\ROMS
21:32:52.2  11/26/2005:  Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
21:32:52.2  11/26/2005:  controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
21:32:52.3  11/26/2005:  History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
21:32:52.3  11/26/2005:  nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
21:32:52.3  11/26/2005:  MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
21:32:52.4  11/26/2005:  Loading Controls.ini map file
21:32:52.5  11/26/2005:  Loading Custom Emulators
21:32:52.5  11/26/2005:  Loading Emulator 2: Nintendo SNES games
21:32:52.7  11/26/2005:  Loading OfflineList Dat File for emulator: 2
21:32:52.7  11/26/2005:  Cannot Find Offline List Dat File
21:32:53.5  11/26/2005:  Snap Path is: C:\mame32\SNAPSHOTS
21:32:53.5  11/26/2005:  AVI Snap Path: Not Found
21:32:53.5  11/26/2005:  Flyer Path is: C:\mame32\FLYERPACKS
21:32:53.6  11/26/2005:  Cabinet Path is: C:\mame32\CABINETS
21:32:53.6  11/26/2005:  Title Path is: C:\mame32\titles
21:32:53.6  11/26/2005:  Panel Path: Not Found
21:32:53.7  11/26/2005:  Icon Path is: C:\mame32\ICONS
21:32:53.7  11/26/2005:  Marquee Path: Not Found
21:32:53.7  11/26/2005:  MAME CMD options: -triplebuffer -nowindow -joy
21:32:53.7  11/26/2005:  Attempting to load game list
21:32:54.3  11/26/2005:  Loading last used Game List
21:32:57.7  11/26/2005:  Creating DirectSound Device
21:32:57.8  11/26/2005:  Trying: Primary Sound Driver
21:32:57.8  11/26/2005:  Loading Sound Files
21:32:58.1  11/26/2005:  DirectSound Device Created Successfully
21:32:58.1  11/26/2005:  Creating ICONS
21:32:58.2  11/26/2005:  Restoring Cached ICONS from File
21:32:59.7  11/26/2005:  Initialising DirectInput for Gamepad support
21:32:59.8  11/26/2005:  Unable to create a joystick device
21:32:59.8  11/26/2005:  Initialising DirectInput for Keyboard support
21:33:00.0  11/26/2005:  Playing intro sound file
21:33:00.0  11/26/2005:  Initializing MCE Remote
21:33:00.1  11/26/2005:  Initialization OK! Starting GameEx!
21:33:00.2  11/26/2005:  Testing Main Loop Once: Processing Frame
21:33:01.2  11/26/2005:  Testing Main Loop Once: Main Loop ran successfully
21:33:06.1  11/26/2005:  Validating: Emulator_2: Custom Background: C:\Program Files\OfflineList0.7\imgs\SNES - Official OfflineList
21:33:06.1  11/26/2005:  Warning: Emulator_2: Custom Background Does not exist
21:33:06.1  11/26/2005:  Validating: Emulator_2: Snap Path: C:\Program Files\OfflineList0.7\imgs\SNES - Official OfflineList
21:33:06.1  11/26/2005:  Warning: Emulator_2: Snap Path Does not exist
21:33:06.1  11/26/2005:  Validating: Emulator_2: Title Snap Path: G:\zsnes\titles
21:33:06.2  11/26/2005:  Warning: Emulator_2: Title Snap Path Does not exist
21:33:06.2  11/26/2005:  Validating: Emulator_2: Box Art Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
21:33:06.2  11/26/2005:  Warning: Emulator_2: Box Art Path Does not exist
21:33:06.3  11/26/2005:  Validating: Emulator_2: Cart Art Path: G:\zsnes\CartScans SNES USA
21:33:06.3  11/26/2005:  Warning: Emulator_2: Cart Art Path Does not exist
21:40:28.1  11/26/2005:  Exiting GameEx!
21:40:28.4  11/26/2005:  Saving Settings
21:40:29.4  11/26/2005:  Writing Game List to disk
21:40:29.6  11/26/2005:  Checking for applications to Launch On Exit
[email protected]
Hey movieman
Your post is not really to do with the original post which is "GameEx 5.23 Released", other posts relate to this release hence being "On Topic". Your last two threads are really OT (off topic) and deserve a new topic. Sorry to be on your back about this, but I'm trying to help you learn the way things are on a forum. Your obviously new to all this, so it's okay. Also, talk about ROMs is frowned upon, so try to keep talk about that to a minimum. And pasting your error log over and over is not needed 99% of the time, so only paste it if we ask for it, thanks.
As for your problem with znes, try changing:
Emu_2 Rom Filter: *.zip
to
Emu_2 Rom Filter: *.smc;*.fig
Hey movieman
to
nope i pasted it there just like you said i did not work here is the log file below
23:04:24.7 11/26/2005: GameEx: Version 5.23: Starting Log
23:04:24.9 11/26/2005: Operating System Platform: Win32NT
23:04:24.9 11/26/2005: Operating System Name: Windows XP
23:04:24.9 11/26/2005: Operating System Version: 5.1.2600
23:04:24.9 11/26/2005: Checking Registration
23:04:24.9 11/26/2005: Running Randomize()
23:04:25.0 11/26/2005: Initialising Video/MNG DLL's
23:04:25.2 11/26/2005: Running Misc startup tasks
23:04:25.2 11/26/2005: Setting Menu types
23:04:25.2 11/26/2005: Opening Configuration File
23:04:25.2 11/26/2005: Getting Configuration Values
23:04:25.3 11/26/2005: Using Theme: Default - Default
23:04:25.3 11/26/2005: Checking for alternate Image Directory for Theme: Default - Default
23:04:25.4 11/26/2005: Text/Language: English
23:04:25.4 11/26/2005: Applying Language/Text
23:04:25.5 11/26/2005: Custom Keyboard Input enabled: Getting custom codes
23:04:25.5 11/26/2005: Creating Scancodes.txt (List of DirectInput scan codes)
23:04:25.6 11/26/2005: Snap Delay set to: 3
23:04:25.6 11/26/2005: Is Media Center running?
23:04:25.6 11/26/2005: Check Media Center Exit/Start Mode
23:04:25.7 11/26/2005: Media Center Mode 2
23:04:25.7 11/26/2005: Checking for applications to Launch On Startup
23:04:25.7 11/26/2005: Get other settings
23:04:25.7 11/26/2005: Using 2D Animations
23:04:25.8 11/26/2005: Desktop set to Hide ICONS and set Background to Black
23:04:25.8 11/26/2005: Backing up Registry Wallpaper Settings
23:04:25.8 11/26/2005: Using DirectInput for keyboard input
23:04:25.9 11/26/2005: Start work for Form
23:04:25.9 11/26/2005: Getting Original Screen Size
23:04:26.0 11/26/2005: Loading ICON
23:04:26.2 11/26/2005: Initializing Component
23:04:26.4 11/26/2005: Initialising Bass Audio Library
23:04:27.2 11/26/2005: Loading default loading screen
23:04:27.4 11/26/2005: Using General Font: Trebuchet MS
23:04:27.4 11/26/2005: Using Title Font: Trebuchet MS
23:04:27.4 11/26/2005: Initialising DirectDraw
23:04:28.1 11/26/2005: Creating DirectDraw Device
23:04:28.8 11/26/2005: Creating DirectDraw Surfaces
23:04:28.8 11/26/2005: Creating Primary Surface - Windowed Mode
23:04:28.9 11/26/2005: Creating Back Buffer
23:04:28.9 11/26/2005: Loading graphic surfaces
23:04:29.1 11/26/2005: Creating Surfaces Misc and Dialogs
23:04:29.4 11/26/2005: Creating Surface Volume
23:04:29.5 11/26/2005: Creating Surfaces Arrows
23:04:29.5 11/26/2005: Creating Surfaces GameEXlogo Text
23:04:29.6 11/26/2005: Creating Surfaces Toolbar
23:04:30.1 11/26/2005: Creating Surfaces Backgrounds
23:04:30.4 11/26/2005: Creating Surfaces Toolbar Controls
23:04:30.5 11/26/2005: Creating Surfaces GameEx Logo
23:04:30.6 11/26/2005: Creating Surfaces Home & Exit
23:04:30.7 11/26/2005: Creating Surfaces Snaps
23:04:30.7 11/26/2005: Creating Surfaces Menu and List Bars
23:04:31.2 11/26/2005: Creating Fonts
23:04:31.2 11/26/2005: Creating Menu Font
23:04:31.6 11/26/2005: Creating Game Font
23:04:31.9 11/26/2005: Creating Game Font Standard Size
23:04:32.5 11/26/2005: Creating Font Black
23:04:32.7 11/26/2005: Creating Font Black Small
23:04:32.9 11/26/2005: Creating Game Font Faded
23:04:33.0 11/26/2005: Creating Title Font
23:04:33.6 11/26/2005: Fonts Created Succesfully
23:04:58.8 11/26/2005: Initialising Windows Media Player Component
23:04:59.7 11/26/2005: MAME Path is: C:\mame32
23:04:59.8 11/26/2005: MAME EXE file is: Mame32.exe
23:04:59.8 11/26/2005: ROM Path is: C:\mame32\ROMS
23:04:59.9 11/26/2005: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
23:04:59.9 11/26/2005: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
23:05:00.0 11/26/2005: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
23:05:00.0 11/26/2005: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
23:05:00.0 11/26/2005: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
23:05:00.0 11/26/2005: Loading Controls.ini map file
23:05:00.1 11/26/2005: Loading Custom Emulators
23:05:00.2 11/26/2005: Loading Emulator 2: Nintendo SNES games
23:05:00.2 11/26/2005: Loading OfflineList Dat File for emulator: 2
23:05:00.3 11/26/2005: Cannot Find Offline List Dat File
23:05:01.1 11/26/2005: Snap Path is: C:\mame32\SNAPSHOTS
23:05:01.1 11/26/2005: AVI Snap Path: Not Found
23:05:01.2 11/26/2005: Flyer Path is: C:\mame32\FLYERPACKS
23:05:01.2 11/26/2005: Cabinet Path is: C:\mame32\CABINETS
23:05:01.2 11/26/2005: Title Path is: C:\mame32\titles
23:05:01.3 11/26/2005: Panel Path: Not Found
23:05:01.3 11/26/2005: Icon Path is: C:\mame32\ICONS
23:05:01.3 11/26/2005: Marquee Path: Not Found
23:05:01.4 11/26/2005: MAME CMD options: -triplebuffer -nowindow -joy
23:05:01.4 11/26/2005: Attempting to load game list
23:05:01.8 11/26/2005: Running: Mame32.exe -help
23:05:02.0 11/26/2005: Running: C: C:\mame32\Mame32.exe -help > C:\mame32\help.txt
23:05:06.1 11/26/2005:
23:05:06.1 11/26/2005: Now Outputing Mame32.exe - Help
23:05:06.2 11/26/2005:
23:05:06.2 11/26/2005: --BEGIN--
23:05:06.2 11/26/2005: M.A.M.E. v0.102 (Nov 14 2005) - Multiple Arcade Machine Emulator
23:05:06.2 11/26/2005: Copyright © 1997-2005 by Nicola Salmoria and the MAME Team
23:05:06.3 11/26/2005: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
23:05:06.3 11/26/2005: several arcade machines. But hardware is useless without software, so an image
23:05:06.3 11/26/2005: of the ROMs which run on that hardware is required. Such ROMs, like any other
23:05:06.3 11/26/2005: commercial software, are copyrighted material and it is therefore illegal to
23:05:06.4 11/26/2005: use them if you don't own the original arcade machine. Needless to say, ROMs
23:05:06.4 11/26/2005: are not distributed together with MAME. Distribution of MAME together with ROM
23:05:06.4 11/26/2005: images is a violation of copyright law and should be promptly reported to the
23:05:06.4 11/26/2005: authors so that appropriate legal action can be taken.
23:05:06.5 11/26/2005: Usage: MAME gamename [options]
23:05:06.5 11/26/2005: MAME -showusage for a brief list of options
23:05:06.5 11/26/2005: MAME -showconfig for a list of configuration options
23:05:06.6 11/26/2005: MAME -createconfig to create a mame.ini
23:05:06.6 11/26/2005: For usage instructions, please consult the file windows.txt
23:05:06.7 11/26/2005: --END--
23:05:06.8 11/26/2005: Loading last used Game List
23:05:09.5 11/26/2005: Creating DirectSound Device
23:05:09.6 11/26/2005: Trying: Primary Sound Driver
23:05:09.7 11/26/2005: Loading Sound Files
23:05:09.9 11/26/2005: DirectSound Device Created Successfully
23:05:10.0 11/26/2005: Creating ICONS
23:05:10.1 11/26/2005: Restoring Cached ICONS from File
23:05:12.1 11/26/2005: Initialising DirectInput for Gamepad support
23:05:12.2 11/26/2005: Unable to create a joystick device
23:05:12.3 11/26/2005: Initialising DirectInput for Keyboard support
23:05:12.4 11/26/2005: Playing intro sound file
23:05:12.5 11/26/2005: Initializing MCE Remote
23:05:12.6 11/26/2005: Initialization OK! Starting GameEx!
23:05:12.7 11/26/2005: Testing Main Loop Once: Processing Frame
23:05:13.4 11/26/2005: Testing Main Loop Once: Main Loop ran successfully
23:05:52.3 11/26/2005: Validating: Emulator_2: Custom Background: C:\Program Files\OfflineList0.7\imgs\SNES - Official OfflineList
23:05:52.3 11/26/2005: Warning: Emulator_2: Custom Background Does not exist
23:05:52.3 11/26/2005: Validating: Emulator_2: Snap Path: C:\Program Files\OfflineList0.7\imgs\SNES - Official OfflineList
23:05:52.4 11/26/2005: Warning: Emulator_2: Snap Path Does not exist
23:05:52.4 11/26/2005: Validating: Emulator_2: Title Snap Path: G:\zsnes\titles
23:05:52.4 11/26/2005: Warning: Emulator_2: Title Snap Path Does not exist
23:05:52.5 11/26/2005: Validating: Emulator_2: Box Art Path: G:\zsnes\Boxscans_SNES_(USA)_28May04
23:05:52.5 11/26/2005: Warning: Emulator_2: Box Art Path Does not exist
23:05:52.5 11/26/2005: Validating: Emulator_2: Cart Art Path: G:\zsnes\CartScans SNES USA
23:05:52.6 11/26/2005: Warning: Emulator_2: Cart Art Path Does not exist
23:07:05.6 11/26/2005: Writing Game List to disk
23:07:07.3 11/26/2005: Updating MAME Game List
23:07:07.5 11/26/2005: Running: C: C:\mame32\Mame32.exe -listxml > C:\mame32\listinfo.dat
23:07:40.0 11/26/2005: Opening Listinfo.dat
23:07:41.7 11/26/2005: Reading ListInfo.dat
23:08:27.8 11/26/2005: Reading ListInfo.dat - DONE
23:08:27.9 11/26/2005: Processing ListInfo.dat
23:08:33.8 11/26/2005: Listinfo.dat Processing Complete
23:08:34.0 11/26/2005: Sorting MAME Game List
23:08:34.7 11/26/2005: Adding History.dat info to gamelist
23:10:08.3 11/26/2005: Adding Catver.ini info to gamelist
23:11:29.5 11/26/2005: Adding Nplayers.ini info to gamelist
23:12:38.6 11/26/2005: Writing MAME Game List To File
23:12:50.7 11/26/2005: Adding MAMEInfo.dat info to gamelist
23:13:38.8 11/26/2005: Updating Year List
23:13:38.9 11/26/2005: Updating Manufacturer List
23:13:39.1 11/26/2005: Updating Category List
23:13:39.3 11/26/2005: Writing Year List To File
23:13:39.4 11/26/2005: Writing Manufacturer List To File
23:13:39.5 11/26/2005: Writing Category List To File
23:13:39.6 11/26/2005: Recreating ICONS
23:13:56.2 11/26/2005: Loading Game List
23:14:33.7 11/26/2005: Exiting GameEx!
23:14:33.9 11/26/2005: Saving Settings
23:14:34.8 11/26/2005: Writing Game List to disk
23:14:35.0 11/26/2005: Checking for applications to Launch On Exit
Emu_2 Rom Filter: *.smc;*.fig  nothing i did not work now here is the gameex log
do you think tom speirs would update gameex and put in the Snes9X emulator cause the snes roms come up on that emulator right away it reads those but for some reason it is not reading these snes roms on the gameex why can you help still
Im uploading 5.24 now which fixes the desktop issues. Its not to send keys. As I tried to explain in this release notes the wait now has an alternate function, in that this is the wait before it kills hideos.exe so the running emulator if just showing in a normal maximized window (not using directx) will then show.
Believe me the other method was very unreliable. This is much better.
There are better ways of doing this, that don't involve waiting. For example, if you use CreateProcess() to launch a program then WaitForInputIdle(), you can then EnumWindows() to match a window handle to the process ID. Once you have the handle you can force it to the foreground and top of z order, thus forcing any other screen into the background. I also have code which can achieve the same result from launching shortcuts (*.lnk). Normally getting a window handle of a program launched by a shortcut is difficult.
