I was having the hardest time trying to configure some new buttons using mame32s through GameEx. When I would press enter and tap a new key I would always also get an O or a K in the field. Is gameEx constantly sending an OK key press to bypass the disclaimers? This is not a huge problem as I can configure games straight through mame.
Where I was thinking this could be a problem is my HotRod SE encoder does not like many more key presses then I already assault it with. Can this be the cause to the occasional joystick gets "stuck" in one direction for a couple seconds at a time problem?
It does stop sending OK after 5-20 seconds, maybe I need to lower how long.
Tom, have you tried using the WaitForInputIdle() API function just after launching Mame, then sending the "OK" then instead of sending it over and over?
Thanks for the tip. I will try it, see if it works
