Hi,
I created a shortcut and placed it under All Users >> Start Menu >> startup (also tried under the admin user)
However when the system starts up and Gameex tries to start the following error is thrown
RRORS DETECTED: EXITING
08:58:46.4 12/01/2010: Error in the application.
08:58:46.5 12/01/2010: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
08:58:46.5 12/01/2010: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
08:58:46.5 12/01/2010: at j.f(Boolean A_0)
08:58:46.5 12/01/2010: at j.af()
08:58:46.5 12/01/2010: It was detected you experienced a DirectX error.
08:58:46.5 12/01/2010: Please note the following for possible solutions to your problem:
08:58:46.5 12/01/2010: 1. Ensure you have the latest version of DirectX installed.
08:58:46.5 12/01/2010: 2. Ensure you have the latest Manufacturer provided video card drivers.
08:58:46.5 12/01/2010: NOTE: Windows/Microsoft Update does not contain the latest.
08:58:46.5 12/01/2010: NOTE: Manufacturer normally means ATI, NVidia, or Intel. Not the brand.
08:58:46.5 12/01/2010: www.ati.com www.nvidia.com
08:58:46.5 12/01/2010: 3. If you do not have a modern video card try the following. 1. Turn off advanced Graphics. 2. Try a lower resolution. 3. Try turning on and using 16-bit colour
08:58:46.5 12/01/2010: 4. Ensure any required video codecs are installed.
08:58:46.5 12/01/2010: 5. Try a different theme, or try running the theme at the resolution it was designed for
08:58:46.5 12/01/2010: 6. Try the latest version of GameEx. GameEx is updated all the time.
08:58:46.5 12/01/2010: 7. If you performed an auto update to this version. Try performing a manual download and install.
It works fine if I then try to open it up after though.
Any ideas?
Cheers
Dan
Hi,
Any ideas?
Cheers
Dan
Im guessing you have some video card driver loading as a service, perhaps even a try utility exists. That is not loaded immediately when gameex is called so your getting the directX error.
you can create a AHK script to wait 3-5 seconds then call Gameex, this may delay enough to run successfully.
This was my vague assumption. I might just knock up a quick DOS script to do this for me
cheers for the suggestion. I am using ArcadeVGA and it may be the control centre for catalyst
