Hi
hope somebody can helphad gameex set up many times with no trouble.
But i just cannot get it to run now.
Mame works on its own and i have an old version ov mame but all roms work in it .
So i dont realy want to upgrade mame it is mame32.
I have always used this with gameex,
I have d/loaded gameex twice now saved it to desktop and then installed.
I have tried basic and advanced install.
Please help just cannot figure it out.
I will paste log but not that good at some things cheers Peter
05:37:08.0 29/12/2009: GameEx: Version 10.34: Starting Log
05:37:08.0 29/12/2009: Operating System Platform: Win32NT
05:37:08.0 29/12/2009: Operating System Name: Windows XP
05:37:08.0 29/12/2009: Operating System Version: 5.1.2600
05:37:08.0 29/12/2009: Checking for versions of .net Framework installed
05:37:08.0 29/12/2009: .net Framework 1.1 Installed
05:37:08.0 29/12/2009: .net Framework 2.0 Installed
05:37:08.0 29/12/2009: .net Framework 3.0 Installed
05:37:08.0 29/12/2009: .net Framework 3.5 Installed
05:37:08.1 29/12/2009: Intel® Pentium® 4 CPU 1.60GHz, 511MB
05:37:08.1 29/12/2009: 1.6Ghz
05:37:08.1 29/12/2009: Running Randomize()
05:37:08.1 29/12/2009: Loading PlugIns
05:37:08.3 29/12/2009: Loaded Plugin:"Speak Game Name" Version 1.41 By Tom Speirs
05:37:08.3 29/12/2009: PlugIn: "Speak Game Name" Initialized OK
05:37:08.3 29/12/2009: Using Plugin System Version: 1.4
05:37:08.3 29/12/2009: Loaded Plugin:"Random Arcade Sound" Version 1.11 By Tom Speirs
05:37:08.3 29/12/2009: PlugIn: "Random Arcade Sound" Initialized OK
05:37:08.3 29/12/2009: Checking for applications to Launch On Startup
05:37:08.3 29/12/2009: Running Misc startup tasks
05:37:08.3 29/12/2009: Setting Menu types
05:37:08.4 29/12/2009: Opening Configuration File
05:37:08.4 29/12/2009: Getting Configuration Values
05:37:08.4 29/12/2009: Using Theme: Default - RedEx - MCE1024x768
05:37:08.4 29/12/2009: Checking for alternate Image Directory for Theme: Default - RedEx - MCE1024x768
05:37:08.4 29/12/2009: Launching HideOS.exe
05:37:08.4 29/12/2009: Initialising Video/MNG DLL's
05:37:08.4 29/12/2009: GameEx will check for media insertion (may affect performance)
05:37:08.4 29/12/2009: Hiding Taskbar
05:37:08.5 29/12/2009: Using Cabinet Friendly Control System
05:37:08.5 29/12/2009: Is Media Center running?
05:37:08.5 29/12/2009: Checking/Creating LCD Registry values
05:37:08.5 29/12/2009: Check Media Center Exit/Start Mode
05:37:08.5 29/12/2009: Media Center Mode 2
05:37:08.6 29/12/2009: Video previews on. Warning: Only recommended on modern systems
05:37:08.6 29/12/2009: Custom Keyboard Input enabled: Getting custom codes
05:37:08.6 29/12/2009: Advanced Custom Keyboard Input enabled: Getting custom codes
05:37:08.6 29/12/2009: Custom Game Device Input enabled: Getting custom codes
05:37:08.7 29/12/2009: Snap Delay set to: 2
05:37:08.7 29/12/2009: Get other settings
05:37:08.8 29/12/2009: Desktop set to Hide ICONS and set Background to Black
05:37:08.8 29/12/2009: Set: Find emulator artwork on best match basis
05:37:08.8 29/12/2009: SlikStik support enabled
05:37:08.8 29/12/2009: Using DirectInput for keyboard input
05:37:08.9 29/12/2009: Start work for Form
05:37:08.9 29/12/2009: Getting Original Screen Size
05:37:08.9 29/12/2009: Opening Database Connection
05:37:09.1 29/12/2009: Initializing Component
05:37:09.2 29/12/2009: Retrieving resolution setting
05:37:09.3 29/12/2009: Initialising Windows Media Player Component
05:37:09.3 29/12/2009: MAME Path is: C:\Emulators\MAME
05:37:09.3 29/12/2009: ZiNc Path is: C:\Emulators\ZiNc
05:37:09.3 29/12/2009: Cannot Find ZiNc Path
05:37:09.3 29/12/2009: Disabling ZiNc support
05:37:09.3 29/12/2009: MAME EXE file is: MAME32.exe
05:37:09.3 29/12/2009: ROM Path is: C:\Emulators\MAME\roms
05:37:09.3 29/12/2009: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
05:37:09.3 29/12/2009: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
05:37:09.3 29/12/2009: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
05:37:09.3 29/12/2009: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
05:37:09.3 29/12/2009: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
05:37:09.4 29/12/2009: Loading Controls.ini map file
05:37:09.5 29/12/2009: Snap Path is: C:\Emulators\MAME\snap
05:37:09.5 29/12/2009: AVI Snap Path: Not Found
05:37:09.5 29/12/2009: Flyer Path is: C:\Emulators\MAME\flyers
05:37:09.5 29/12/2009: Cabinet Path is: C:\Emulators\MAME\cabinets
05:37:09.5 29/12/2009: Title Path is: C:\Emulators\MAME\titles
05:37:09.5 29/12/2009: PCB Path: Not Found
05:37:09.5 29/12/2009: Artwork Preview Path: Not Found
05:37:09.5 29/12/2009: Panel Path is: C:\Emulators\MAME\cpanel
05:37:09.5 29/12/2009: Manual Path: Not Found
05:37:09.5 29/12/2009: Icon Path is: C:\Emulators\MAME\icons
05:37:09.5 29/12/2009: Marquee Path is: C:\Emulators\MAME\marquees
05:37:09.5 29/12/2009: Loading Custom Emulators
05:37:09.5 29/12/2009: Loading Emulator 1: Mame
05:37:09.6 29/12/2009: Loading Emulator 2: [Arcade] Nebula
05:37:09.6 29/12/2009: Error: Emulator_2: RomPath is Invalid
05:37:09.7 29/12/2009: Please correct the error above for this emulator or disable the emulator.
05:37:09.7 29/12/2009: Error: Emulator Configuration Error
05:37:09.7 29/12/2009: at j.a(Int32 A_0, String A_1)
05:37:09.7 29/12/2009: at j.av()
05:37:09.7 29/12/2009: at j.a(Boolean A_0, String A_1, Boolean A_2)
05:37:09.7 29/12/2009: at j..ctor()
05:37:09.7 29/12/2009: Closing database connection
05:37:09.7 29/12/2009: Disposing Plugins
05:37:09.7 29/12/2009: GameEx is exiting with errors
05:37:09.7 29/12/2009: Deleting search cache
05:37:11.7 29/12/2009: ERRORS DETECTED: EXITING
This part of the log tells you the problem and how to fix it.
So you need to go and check your RomPath for Emulator 2 ([Arcade] Nebula).
Thanks HEADKAZE
i could see the fault but could not figure out how to sort it,
thanks for the quick reply.
Will try to do it now cheers Peter.
hope i have posted this right
