Can someone explain or tell me how I can have Xppader launch and close from Game Ex on certain emulators? I want to be able to have Xpadder launch before certain emulators when I start them and then exit out it when I close that emulator before going back into Game Ex.
Thanks.
Have you tried the launch before and launch after to open and then close Xpadder
for xp, vista, windows 7 "taskkill /IM ??????.exe /F"
  On 12/6/2009 at 6:57 AM, smd111 said:
Have you tried the launch before and launch after to open and then close Xppader
I understand the launch before but how do I tell the launch after to close it?
use "taskkill /IM Xpadder.exe /F"
I use a batch file to load my xpadder profiles since I have multiple game pads. If I remember correctly, you might need to do the same though as GameEx didn't seem to play nice with sending profiles. I haven't played with it for a while, but I definitely remember struggling with that and thinking to myself "Damn, this is so dumb...why can't it just work!"
Good luck!
