Hi,
I have a cabinet running GameEx on two screens, the top one is a 15 inch Touchscreen,and the bottom is a 27 inch CRT. The GameEx interface runs on the touchscreen, and when an emulator is selected, a script is run that makes the CRT the main display, the game presents on it, and the Touchscreen ends up displaying Marquee data. Upon exit, the reverse happens, sending GameEx back to the touch screen.
This works just fine.
My question is this, Is it possible to separate integrated GameEx functions, so they can be directed to different screens in a multi monitor setup ? For example, play a DVD on one monitor, while keeping the transport controls on another, or perhaps music selection on one, and visuals on a second ? - You get the idea. I have tried setting up a hotkey I can use to force GameEx to move from screen to screen, but this method angers DirectX, and ultimately results in crashing GameEx.
Thanks - Miskie.
hia there
sorry to jump in on ya post, i like to give this ago an setup two screens on my gameex setup
can i ask how you go about doing this, i did try looking for info on what i need to do
im running an arcade vga with gameex.
any help or info be sweet
thanx carl.
