Hello, Ive done several searches and read many thread, so Im hoping this isnt as simple as "read here" :)
I have read that the only way to set gameex to read iso's is at install. Is this ever going to be configurable later. If not, is the uninstall / reinstall process pretty smooth? It scares me to lose all the settings for the games and control panel ive been tweaking for a long time. But I would love to use ISOs.
And last, can someone give me the command line to run cyberlink from DVD files in the launcher? Ok, I havent looked for it yet, so i can probably find it. Or, what is your favorite dvd player for gameex?
Thanks a bunch.
Thanks a bunch.
Its normally smooth. No need to uninstall just install again.
You should just be able to use the path to the executable. You might need yo put it in quotes. Otherwsie GameEx can use its own player and just use the codec installed.
Thanks - everything went smooth.
Now I just need to figure out how to use the movie database everybody's talking about...
--found it!, thanks! --
