I have an odd problem, just tried to shell my system since updating the hard drives and reinstalling Windows (XP 64bit). Shelling works fine but I cant reload the desktop using explorer. When I run explorer from taskmanager, windows explorer loads and displays my docs folder, no desktop.
Any ideas before I do a repair install?
thank you
no, that happens, not sure if a reinstall will fix it. your beter off mkaing a seperate admin account, then using instant sheller to only shell for the current account,
Enable remote desktop then sign into your cab from another PC using the secound account for all your cab administration needs.
