Using roms from CD/DVD in gameex [ problem ]
I ve tried new version on gameex but i see there are some problems with running roms when roms are set up as [drive letter] dvd.
If my roms folder points directly to the dvd drive i cant run roms from there [when i try to run a romfile noting happens [even gameex dont tries to run file] and going back to the menu]. Previous instalations of gameex run everything fine
example
http://img269.imageshack.us/img269/6526/96666007.jpg
example
Can you export and post the emulator config in question?
I've seen this before, it is when your ROMPATH= is the ROOT of a drive,
EG. D:\,c:\,f:\
EG. D:\,c:\,f:\
Yes its only happens when ROMDIR points directly to the ROOT of DVD Drive [ i dont remebner which version but few version back GameEx supports romdir -> cd/dvd root drive with no problems]. I think GameEx 10.00 runs everything ok..
Do we have solution for this?
