Thanks for reading, I have had GameEx running before on a different system, but I had to scrap it & start fresh!!
Here is an error message after recently installing, I can usually work the problem however this message leaves me wondering what the heck?! I have no idea what the problem is!
Could anybody help?
Thanks in advance.. I appreciate it.
22:10:24.4 03/09/2009: Is Media Center running?
22:10:24.4 03/09/2009: Checking/Creating LCD Registry values
22:10:24.5 03/09/2009: Check Media Center Exit/Start Mode
22:10:24.5 03/09/2009: Media Center Mode 2
22:10:24.5 03/09/2009: Video previews on. Warning: Only recommended on modern systems
22:10:24.6 03/09/2009: Snap Delay set to: 2
22:10:24.6 03/09/2009: Get other settings
22:10:24.6 03/09/2009: Desktop set to Hide ICONS and set Background to Black
22:10:24.6 03/09/2009: Set: Find emulator artwork on best match basis
22:10:24.6 03/09/2009: Start work for Form
22:10:24.7 03/09/2009: Getting Original Screen Size
22:10:24.8 03/09/2009: Opening Database Connection
22:10:29.1 03/09/2009: --**--
22:10:29.1 03/09/2009: Error: No error message available, result code: REGDB_E_CLASSNOTREG(0x80040154).
22:10:29.7 03/09/2009: at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection)
22:10:29.7 03/09/2009: at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject)
22:10:29.7 03/09/2009: at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup)
22:10:29.7 03/09/2009: at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
22:10:29.7 03/09/2009: at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
22:10:29.7 03/09/2009: at System.Data.OleDb.OleDbConnection.Open()
22:10:29.7 03/09/2009: at u.a(Boolean A_0, String A_1, Boolean A_2)
22:10:29.7 03/09/2009: at u..ctor()
22:10:29.8 03/09/2009: Disposing Plugins
22:10:29.8 03/09/2009: GameEx is exiting with errors
22:10:31.6 03/09/2009: ERRORS DETECTED: EXITING
Looks like a databse error to me. You have to download the databases yourself. Does that make sense? Are you telling GameEx to use databases that you don't have?
Is this a standard installation of Windows or is it a cut down version? Some of the lite versions don't include some database stuff that GameEx needs.
Thanks for your reply,
Are you referring to the files stored in C:\Program Files\GameEx\DATA\EMULATORS?
I have all these & I have just downloaded them again to see if it would fix the problem but it does not. Do I need any other additional files?
I have Windows XP standard.
Thanks..
