19th November 2005 - Instant Sheller 0.31
Instant Sheller 0.31 released
Instant Sheller is a one click solution to shell any frontend in Windows XP completely hiding any trace of Windows. It features an undo so it should be stress free.
With version 0.31 you can modify the Windows boot screen. A GameEx image is included.
Version 0.31 should also fix the auto login issue after second boot.
You should set this program in GameEx before using it.
This way, you should be able to access it without troubles to undo the settings later if needed.
