Hey Tom, great work with the software, I love it. I just Downloaded and installed 5.17 and got this message:
18:16:02.8 11/17/2005: GameEx: Version 5.17: Starting Log
18:16:02.8 11/17/2005: Operating System Platform: Win32NT
18:16:02.8 11/17/2005: Operating System Name: Windows XP
18:16:02.8 11/17/2005: Operating System Version: 5.1.2600
18:16:02.8 11/17/2005: Checking Registration
18:16:02.8 11/17/2005: Running Randomize()
18:16:02.8 11/17/2005: Initialising Video/MNG DLL's
18:16:02.9 11/17/2005: Unable to load DLL (PlayVideoBak.dll).
18:16:03.0 11/17/2005: ERRORS DETECTED: EXITING
What should I do now? I reinstalled but I get the same message after installing. I don't use the video features anyhow, can I turn something off in the config to prevent this or does PlayVideoBak.dll load regardless of the settings? Thanks for the help.
This is likely because you installed .net framework version 2.0 from windows update. GameEx is currently not working if 2.0 is installed. Just uninstall it from Control Panel, and make sure you still have v 1.1 installed.
Cheers.
Cheers.
That was it, thanks again for the hard work Tom. :D
