I've been using GameEx (Registered user) for about two months now and have run into a couple of issues with the Jukebox...
The Start/Stop Jukebox function is really flaky: It takes up to five presses sometimes to register a start/stop, no matter what key I assign it to.
Selecting "Visualize" clears the playlist of everything but the playing track once you exit the visualization. Note that I don't use static playlists, instead generating the shuffling them whenever GameEx is restarted. I also use no WMP functionality.
I think thats the problem right there. In order to run the Visualizations GameEx has to use WMP. So I believe it has to move the playlist over and to WMP for that function.
