Im thinking about installing instant shell to setup a shell but I was just wondering, If i need to gain access to the os to put in more files etc is this possible??
Hey,
I just exit gameex and bring up taskmanager, from there you can run the command explorer.
IE: Ctrl + Alt + Del > Task Manager > File > Create New Task and enter explorer and hit ok.
I guess you could create a menu entry or batch file to exit and then run explorer.
