Here's my Mame Emu Map for use with GameEx. It replaces the laser disc games already in Mame but not yet playable with Daphne. The other Daphne games not in Mame at all are inserted. The Dice games (Pong, Gotcha, and Rebound) and also inserted (not in Mame). The Naomi games playable on NullDc are swapped. Finally (and thanks to Tempest) Radikal Bikers is switched from Mame to the much nicer emu by Aaron Giles, and Ridge Racer, Ridge Racer 2, and Rave Racer are swapped to Vivanonno.
Hopefully all you should need to do is change the numbers below from the existing emulator numbers to whatever the number of the same emulators are in your install of GameEx. The Daphne ones (1000) are all fine as they are. For dice, you'll want to make three batch files in your "roms" directory for that emulator to call pong, gotcha or rebound (since the games themselves are in the emulator executable and called via commandline switches.) I can upload my batch files for Dice if anybody wants them.
Here's the emu map:
# This file allows launching specific MAME roms or rom types
# With an alternative emulator setup in GameEx
# such as an alternate version of MAME or an emulator
# that provides faster emulation.
# Note: a MAME game list update is required after making changes
# here.
# This is a registered version feature
[GENERAL]
# Enable this feature in GameEx and use this file
Enabled=true
# You may not want to list an emulator specified seperatly
# in the GameEx menus
# and make this feature transparent.
# Specify Emulator Numbers seperated by | to hide and use only for MAME
Hide=1000|61|35|49
# Some emulators need the full filename of the rom. ie with the .zip extension
# Specify emulators where the extension should be used seperated by |
Ext=61
# If you want roms for a specific driver to always be visible in the list
# and override any other filters, such as when you dont have the MAME rom
# specify the drivers seperated by |
Driver=
# The following settings tell GameEx when to use an emulator to launch
# instead of MAME. To specifcally specify MAME use 0. To specify Daphne
# use 1000
# Example Launches 1942 rom with emulator 10:
# 1942=10
# Example Launch rom lair with Daphne:
# lair=1000
# As well as the ability to specify an emulator to use
# you can alternativly specify different MAME cmd line options.
# To do this instead of specifying the emulator number use
# =cmd=[Command Line options]
# Example: 1942=cmd=-noswitchres
# To have vertical games launch with an alternate cmd option
# Under [MAPPROPERTIES]:
# Vertical=cmd=[Command]
# Example: Vertical=cmd= -rol
# The options specified will replace any other set
# MAME options
[MAPROMS]
# Specify a list of rom names with an emulator number
# to have GameEx launch the rom with that emulator
# Map ROMS to an emulator on an individual basis
# This overrides any other mappings
# If you want to exclude a rom from any of the other mappings
# Specify it here as 0 (use MAME)
# Specifing a rom and an enabled emulator here will also
# ensure it will override all other filters when updating the
# game list and always be available.
dlair=1000
astron=1000
badlands2=1000
bega=1000
cliffhgr=1000
cobraseg=1000
esh=1000
galaxyr=1000
gpworld=1000
istellar=1000
lair2=1000
raveracw=51
ridgerac=51
ridgera2=51
roadblaster=1000
spaceace=1000
sblazerp=1000
superdq=1000
thayers=1000
cvs2gd=61
cvsgd=61
ggxx=61
ggxxrl=61
meltybld=61
sfz3ugd=61
pong=35
gotcha2=35
rebound=35
radikalb=49
[MAPPROPERTIES]
# This matches roms with the specified properties as below
Analog=0
Cocktail=0
Vertical=0
Gun=0
Trackball=0
Vector=0
Horizontal=0
[MAPDRIVER]
# Specify a list of MAME drivers to map
neogeo=0
[RENAME]
# When a match is found for a rom, rename it to the following
# When passing it to the emulator. The emulator will try to launch the
# new name.
# Example:
# mrdriller=drill.zip
dlair=lair
badlands2=badlands
cliffhgr=cliff
cobraseg=cobraab
galaxyr=galaxy
gotcha2=gotcha
istellar=interstellar
raveracw=rv1
ridgerac=rr1
ridgera2=rrs1
spaceace=ace
sblazerp=blazer
superdq=sdq
thayers=tq
cvs2gd=Capcom vs SNK 2 Millionaire Fighting 2001.bin.lst
cvsgd=Capcom vs SNK Millenium Fight 2000 Pro.lst
ggxx=Guilty Gear XX.lst
ggxxrl=Guilty Gear XX Reload.lst
meltybld=Melty Blood - Act Cadenza.lst
sfz3ugd=Street Fighter Zero 3 Upper.lst
The following sections allow you to add new roms to the game list that are not in MAME.
Specify up to 200 sections as [ADD_[1-200]]. Eg [ADD_1]
If enabled GameEx will add these to the game list on build.
Use the [MAPROMS] and other sections above to specify what emulator to use
based on the rom name.
[ADD_1]
Enabled=true
Rom=lair2
Name=Dragon's Lair 2
Description=Daphne has been kidnapped by the evil wizard Mordroc and Dirk the Daring must rescue her! Travel through time and space in seven levels of twitch-action response to flashing on the screen. The laserdisc provides beautifully animated scenery.
Year=1991
Manufacturer=Leland
Category=Platform / Run Jump
[ADD_2]
Enabled=true
Rom=pong
Name=Pong
Description=A Table Tennis type game. Most people are familiar with it. Keep the ball in play and hope your opponent misses. Pong was released commercially in approximately November 1972. While the 1971 Computer Space machine was the first coin-operated videogame, Pong was the first commercially successful one. The Red and Black countertop unit was the first prototype style placed on location. The Yellow and Brown floor model is the main production style model and can still be found on a regular basis in collections and for sale.
Year=1972
Manufacturer=Atari
Category=Ball & Paddle
[ADD_3]
Rom=gotcha2
Name=Gotcha
Description=Gotcha is a 1973 arcade game manufactured by Atari Inc. It was Atari's fourth game after Pong, Space Race, and Pong Doubles. This was the first maze arcade game, as well as the very first video game to cause a considerable amount of controversy, predating other early examples such as Death Race by several years. The object of the game is for two players to find their way through an on-screen maze, attempting to catch each other. The controversy stemmed from the perception that the game's controls, rather than joysticks, were pink rubber bulges meant to represent breasts. The bulges were squeezed in order to control the action. This was done because some members of Atari jokingly mentioned that joysticks curiously resembled a phallus. As a result, it was decided to create a "female game" and this game was henceforth referred to game as "the boob game" by company staff. Later versions of the cabinet replaced the controls with standard joysticks. The game was not well received by the public.
Year=1973
Manufacturer=Atari
Category=Maze
[ADD_4]
Rom=Rebound
Name=Rebound
Description=Rebound is a 2 player arcade game by Atari Inc., originally released in February of 1974. The game simulates a volleyball match, having players volley a ball back and forth over a net with their paddles. Rebound is also the first game that was cloned and released under the then hidden Atari subsidiary Kee Games, as Spike.
Year=1974
Manufacturer=Atari
[ADD_5]
Rom=bega
Name=Bega's Battle
Description=Bega's Battle was a laser disc game released by Data East in 1983. Most of the scenes from the laser disc of Bega's Battle were for backgrounds only. They were taken from the cartoon "Harmagedon". Computer generated graphics were overlaid on top for the game play.
In Bega's Battle, you play a character named Bega. You must face the alien Varga who is trying to take over the earth. You must defeat Varga to save the earth from destruction. Other goals are to rescue your friends Luna, Jobe, and Sony. Once rescued, Luna gave you extra firepower, Jobe gave you the shield, and Sony gave you teleportation ability.
Year=1983
Manufacturer=Data East
Category=Action
[ADD_6]
Rom=Badlands2
Name=Badlands
Description=In late 1983, most video game companies thought that laser disc games were the future of the gaming industry. Everyone was jumping on the laser disc bandwagon. In early 1984, the team of Konami / Centuri, who at the time was releasing games like Track & Field, Hyper Sports, and Super Basketball, decided to enter the laser disc world with a game called Badlands.
In Badlands, you play a character named Buck, whose wife and children were killed by a group of bad guys. Revenge is the only thing on your mind. You head for town, equipped only with your gun, searching for the people who ruined your life.
Year=1984
Manufacturer=Konami
Category=Action
[ADD_7]
Rom=roadblaster
Name=Road Blaster
Description=Road Blaster was a laser disc game created by Data East in 1985. Your mission is to seek out a gang of bikers who attacked and killed your wife. You are behind the wheel of a souped-up sports car, weaving in and out of traffic and other obstacles while in pursuit of the bikers.
Year=1985
Category=Action
I'd been meaning to try the add roms feature to get pong, but hadn't played with it yet. This will be nice so I can just copy & paste. Thanks Lawrence!
I can't take the credit for Pong -- Tom included that as an example with the update that added support for games outside of MAME.
It is nice having Pong in there -- how many times have you had a friend over and he/she asks, "Cool, does it have Pong?"
