Hi guys - hey Tom - whatup ----- just curious - I know GameEx is compat with Mame and MAME32 - how about MAME32FX? I just tried to play a game in GameEx after setting the path to Mame32FX and when I select "play this game" It goes into launch mode, then reverts back to the menu. Is this due to incompatability, or is there a way to work around this?
THANKS DUDES!
J
THANKS DUDES!
J
Normally MAME32FX does work with GameEx as does MAMEPlus.
Thanks Tom! Awesome FE! Just curious - I just updated my roms to the latest set and all of a sudden, whenever I select "play this game" the screen goes black, then pop - right back to the game info screen.
When I select the update game list option, it recognizes all of the roms fine.
Any ideas?
Thanks!
J
Does the game work if you launch it directly from Mame32FX? Some of my games (Gauntlet Legends for example) is listed, but doesn't work in GameEx. In Mame32, it isn't even listed.
I don't know why this is, but perhaps it's a bug?
Emph
Emph
K - here's the part thats driving me nuts - all the games I select work in Mame32FX, for some reason they just won't launch in GameEx -- it acts like its going to load up, screen goes black, then *pop* - we're back on the game information page.
Tom - I just downloaded and installed regular Mame32 and its doing the same thing - any suggestions?
THANKS SO MUCH DUDES!
J
This sounds like the command line options problem again.
-skipdsclaimer was removed from the .100+ releases. If you still have this in your Gameex command line config then remove it. That should do the trick
Cheers
J
Cheers
J
----And indeed it did! Many thanks!
