Hey guys,
Just wondering if anyone has used any of the Emumovies flv snap packs with GameEx.
I was using an incomplete set of the avi files which are working fine. I downloaded the latest complete release 0.128 flv pack but am having issues getting them to play.
Using GameEx v9.98... Have the latest K-Lite codec pack installed (4.7.5) and the vids play fine through WMP. Windows is also able to create thumbnails for all the files too so I dont think that any are corrupt.
My games list just doesn't show any sign of the snap. I did try to remove the extension on one of the files and then I get the first frame showing as a snapshot image.
I have removed and re-installed the codec pack... Tested the avi's again and they are fine... The flv's just dont show :(
Any thoughts?
Cheers
I have tested flv's and it plays them fine. The only problem was that GameEx didn't recognise the .flv extension which I mentioned to Tom a few times, but he said he fixed that. So not sure? If you rename one of the videos to .avi does it play them then?
BTW I think the Vista Codec pack is the best one these days.
Hey HeadKaze,
You are on to it man :)
Renaming as avi is the solution. All Hunky Dory now. Thanks for that...
Maybe this should be put into the FAQ... Until Tom gets a chance to fix the FLV association.
I'm happy with the K-Lite pack... It does everything I need and isn't overly bloated... At the end of the day its ffdshow doing a lot of the work for me anyway. The only files I use are divx/xvid, dvd, flv, mov and the very occasional mkv.
