Hi there i have a problems with html application
I have set app 3 to open up to http://songza.co.uk
and named it: Online juke box: Search & play
But when i come and select it in GameEx it comes up says loading then it gose to a blank screen and stays like it untill i press Esc
Its also the same when i to and select GameEx (the website not the program)
any ideas?
any ideas?
Just tested and used the site you're using and had no issues on my end. If it's not working with either of the other sites then don't know what else it could be. Are you sure GameEx has permissions to access the internet?
yes m8 it all has permission.
The odd think i have a screen recorder and when i record the screen on playback it shows it on the video but it just dont switch to it when your doing it.
its very very odd i know.
Its almost as if GameEx has loaded it but it just dont switch to the screen so its running in the background but you can not see it.
Right i still having this problem
I just found somethink out that someone might know whats wrong.
When i alt tab out to windows then alt tab back into GameEx it shows then shows the site.
Its doing my head in.
Any ideas?
still not fixed. any ideas would be good.
it was working at one point the i reinstall my pc but it dont work now
Post your log as well as your gameex.ini so we can look further into your current settings and see what's going on.
  Killer said:
Sorry me i entered the url wrong ( me noob of the day :P)
GameEx.ini
Log.ini
They will work now
I just tested using your GameEx.ini on my system and it worked fine. I would say maybe the problem lies in your IE install or something else that is conflicting. Maybe Tom will know.
Ok m8 thank you for your time and trying it out.
looks like this i not going to be a easy fix for me then LOL
time to start fault finding.
i think it my have somethink to do with my ati gfx card now that it not a config problem/bug
