I have the MAME Screensaver and when I run Musicmatch Jukebox, if I step away for awhile with music playing and the screensaver kicks on, it distorts the music. When I come back, the screensaver will be on and the music will sound garbled. If I press stop and then play again, it plays fine. Anybody else have a conflict with MMJukebox and the screensaver or any ideas on how to fix it? Thanks.
Hi, I'm pretty sure this issue is with MAME and not the screensaver, you could try a different build, perhaps not MAME32FX if that's what your using.
Right on. I will check into that. Thanks.
