Can I just copy the contents of my GameEx.ini? Commands like Use advanced graphics and options like that, can it be implemented in the theme.ini file?
I'm about to post my first theme here, and I don't want it to look wrong.
Emph
Emph
Most commands can work in a theme.ini but I would keep the file very small, to only what's required for the theme, such as if it needs to run at a certain resolution. If there really are no special requirements theme.ini can just be a blank file. Which would be a hugely better idea than copying your whole config over. That could cause loads of problems.
If your having touble identifying what the commands are, just ask.
Good luck.
