When playing a mame game, the game will close if you hold 6 and hit 2. How can I stop this from happening?
While in MAME, do the following:
  • Press {TAB}
  • Select Input (general) then press {ENTER}
  • Select User Interface then press {ENTER}
  • Select UI Cancel then press {ENTER}
  • Map the key(s) to what you want
just did that but now the new mapped key closes mame and so does 6 + 2.
When doing that are both combinations displayed on the screen? Maybe you added to the combination instead of clearing out what was there before and adding the new combination.
6 2 Or new combination you just chose is what would be displayed.
There is no way to stop it currently, but why do you need to?
Ahhh sorry! I guess one of those things that is coded into GameEx that I didn't know about since don't have these mappings. Sorry for misleading.
my player 2 coin and start button are mapped as 6 and 2 and are very easily hit at same time causing games to close. just wanted it to change that if possible.
is it a bug or is it there for a purpose?
edit: player 1-4 start is 1 2 3 4 and player 1-4 coin is 5 6 7 8. guess i could change some numbers around or something... still curious as to why 6 and 2 exit
