Hi all,
[issue]
I just upgraded to the latest Gameex 5.09 and when I log in, my screen starts flickering(the nag screen is OK!). Its in the Gameex Menu that words are flickring. The whole screen does not flicker only the bottom half of the screen flickers. However if I downgrade to my old version of Gameex (Im sorry I dont remember the version) then it works fine.
[Machine]
XP with Service Pack2
Nvidia Riva TNT2 Model 64 video card with Nvidia driver - 66.93
[Question]
How can I stop this flickering. Below are my logs for your info. Thanks:
22:53:12.0 14/09/2005: GameEx: Version 5.09: Starting Log
22:53:12.0 14/09/2005: Operating System Platform: Win32NT
22:53:12.0 14/09/2005: Operating System Name: Windows XP
22:53:12.0 14/09/2005: Operating System Version: 5.1.2600
22:53:12.0 14/09/2005: Checking Registration
22:53:12.0 14/09/2005: Running Randomize()
22:53:12.0 14/09/2005: Initialising Video/MNG DLL's
22:53:12.1 14/09/2005: Running Misc startup tasks
22:53:12.1 14/09/2005: Setting Menu types
22:53:12.1 14/09/2005: Opening Configuration File
22:53:12.1 14/09/2005: Getting Configuration Values
22:53:12.1 14/09/2005: Using Theme: Default - Default
22:53:12.1 14/09/2005: Checking for alternate Image Directory for Theme: Default - Default
22:53:12.1 14/09/2005: Text/Language: English
22:53:12.1 14/09/2005: Applying Language/Text
22:53:12.3 14/09/2005: Creating Scancodes.txt (List of DirectInput scan codes)
22:53:12.4 14/09/2005: Snap Delay set to: 1
22:53:12.4 14/09/2005: Is Media Center running?
22:53:12.4 14/09/2005: Check Media Center Exit/Start Mode
22:53:12.4 14/09/2005: Media Center Mode 2
22:53:12.4 14/09/2005: Checking for applications to Launch On Startup
22:53:12.4 14/09/2005: Get other settings
22:53:12.5 14/09/2005: Using 3D Animations
22:53:12.5 14/09/2005: Launching HideOS.exe
22:53:13.7 14/09/2005: Hiding Taskbar
22:53:13.7 14/09/2005: Start work for Form
22:53:13.7 14/09/2005: Getting Original Screen Size
22:53:13.7 14/09/2005: Loading ICON
22:53:13.7 14/09/2005: Initializing Component
22:53:13.8 14/09/2005: Initialising Bass Audio Library
22:53:14.1 14/09/2005: Loading default loading screen
22:53:14.1 14/09/2005: Arcade Mode is on
22:53:14.1 14/09/2005: Using General Font: Arial
22:53:14.2 14/09/2005: Using Title Font: Trebuchet MS
22:53:14.2 14/09/2005: Initialising DirectDraw
22:53:14.3 14/09/2005: Creating DirectDraw Device
22:53:14.3 14/09/2005: Setting Resolution to 800x600 32 bit color
22:53:14.4 14/09/2005: Creating DirectDraw Surfaces
22:53:14.4 14/09/2005: Creating Primary Surface - Full Screen Mode
22:53:14.6 14/09/2005: Creating Back Buffer
22:53:14.6 14/09/2005: Loading graphic surfaces
22:53:14.7 14/09/2005: Creating Surfaces Misc and Dialogs
22:53:14.9 14/09/2005: Creating Surface Volume
22:53:14.9 14/09/2005: Creating Surfaces Arrows
22:53:15.0 14/09/2005: Creating Surfaces GameEXlogo Text
22:53:15.0 14/09/2005: Creating Surfaces Toolbar
22:53:15.3 14/09/2005: Creating Surfaces Backgrounds
22:53:16.9 14/09/2005: Creating Surfaces Toolbar Controls
22:53:17.0 14/09/2005: Creating Surfaces GameEx Logo
22:53:17.0 14/09/2005: Creating Surfaces Home & Exit
22:53:17.1 14/09/2005: Creating Surfaces Snaps
22:53:17.1 14/09/2005: Creating Surfaces Menu and List Bars
22:53:17.6 14/09/2005: Creating Fonts
22:53:17.6 14/09/2005: Creating Menu Font
22:53:18.5 14/09/2005: Creating Game Font
22:53:19.2 14/09/2005: Creating Game Font Standard Size
22:53:19.9 14/09/2005: Creating Font Black
22:53:20.0 14/09/2005: Creating Font Black Small
22:53:20.2 14/09/2005: Creating Game Font Faded
22:53:20.9 14/09/2005: Creating Title Font
22:53:37.1 14/09/2005: Initialising Windows Media Player Component
22:53:37.2 14/09/2005: MAME Path is: E:\Mame
22:53:37.2 14/09/2005: MAME EXE file is: mame.exe
22:53:37.2 14/09/2005: ROM Path is: E:\Mame\roms
22:53:37.2 14/09/2005: Catver.ini is located at: E:\Gameex\GameEx\DATA\catver.ini
22:53:37.2 14/09/2005: History.dat is located at: E:\Gameex\GameEx\DATA\history.dat
22:53:37.2 14/09/2005: nplayers.ini is located at: E:\Gameex\GameEx\DATA\nplayers.ini
22:53:37.2 14/09/2005: MAMEinfo.dat is located at: E:\Gameex\GameEx\DATA\mameinfo.dat
22:53:37.3 14/09/2005: Loading Controls.ini map file
22:53:37.3 14/09/2005: Loading Custom Emulators
22:53:38.0 14/09/2005: Snap Path is: E:\Mame\snap
22:53:38.0 14/09/2005: AVI Snap Path: Not Found
22:53:38.0 14/09/2005: Flyer Path is: E:\Mame\flyers
22:53:38.0 14/09/2005: Cabinet Path is: E:\Mame\cabinets
22:53:38.0 14/09/2005: Title Path: Not Found
22:53:38.0 14/09/2005: Panel Path is: E:\Mame\cpanel
22:53:38.0 14/09/2005: Icon Path is: E:\Mame\icons
22:53:38.0 14/09/2005: Marquee Path is: E:\Mame\marquees
22:53:38.0 14/09/2005: MAME CMD options: -skip_disclaimer -skip_gameinfo -triplebuffer -nowindow -joy -nohws -inipath E:\Mame\INI
22:53:38.1 14/09/2005: Attempting to load game list
22:53:38.4 14/09/2005: Loading last used Game List
22:53:39.2 14/09/2005: Loading music
22:53:39.5 14/09/2005: Creating DirectSound Device
22:53:39.5 14/09/2005: Trying: Primary Sound Driver
22:53:39.5 14/09/2005: Loading Sound Files
22:53:39.6 14/09/2005: DirectSound Device Created Successfully
22:53:39.6 14/09/2005: Creating ICONS
22:53:39.7 14/09/2005: Restoring Cached ICONS from File
22:53:43.3 14/09/2005: Initialising DirectInput for Gamepad support
22:53:43.4 14/09/2005: Unable to create a joystick device
22:53:43.4 14/09/2005: Playing intro sound file
22:53:43.5 14/09/2005: Initializing MCE Remote
22:53:43.5 14/09/2005: Initialization OK! Starting GameEx!
22:53:43.5 14/09/2005: Testing Main Loop Once: Processing Frame
22:53:43.8 14/09/2005: Testing Main Loop Once: Main Loop ran successfully
22:53:51.4 14/09/2005: Exiting GameEx!
22:53:51.4 14/09/2005: Saving Settings
22:53:51.9 14/09/2005: Writing Game List to disk
22:53:56.9 14/09/2005: Checking for applications to Launch On Exit
Hi all,
[issue]
[Machine]
[Question]
Funnily enough I did some testing on a P3 700Mhz with a TNT2 card (same drivers) and got the same thing. GameEx ran full speed but I had the flickering. I have spent some time looking at this, but it appears to be the card. Perhaps an upgrade is due? these cards seem to be at least 5-6 years old. I can't think why the old version worked. If you look at the log for it it will say the version. That might shed some light for me.
Cheers.
Cheers.
Hi Tom,
I will install the older version of GameEx tonight and get you the logs for that.
You are right in that the card is old so maybe an upgrade of card is due.
Flavio
Hi Tom,
Flavio
The version that I was running prior the upgrade was 4.54
Hope that helps.
Hope that helps.
OK, I have a fix for it. It's still deffinitly an issue with the card/drivers, but ther'll be a setting in the next release to fix the flickering for you.
Tom.
