Hi!
On some WHDLoad games, WHDRun display a log in a window when WINUAE has encountered an error in running the game
Is there a way to disable this because when i'm in screensaver mode since an hour, i can see about 15 windows of errors in background and i have to click on "Quit WDRun" button on each window to close them....
Quite annoying...
Thanks ;)
I think I know how to fix this, if you hang around for a bit I'll do an update and you can test it for me if you like?
The problem is if GameEx kills the WinUAE process during the screensaver then there is no way for it to close down whdrun.exe.
The easiest way would be to use an advanced config and add
Process1=whdrun
Let me know if that works for you
My advanced config before your reply was :
Process1=Winuae
Process2=WHDLoader
Now i've changed with your help to :
Process1=winuae
Process2=whdrun
Now i don't see the window on background !! It's great!
Many thanks headkaze for you help very appreciated
