im trying to setup gameboy advance emulator but for some reason the roms dont show up i told it to look for .zip like *.zip and i put it to the right path where my roms are and they are all .zip and it still doesnt show up in gameex and someone help me out
aslo it says this -no games found- but there is a picture of f-zero on the left
i found out how to fix it
well i turned on to remove words in brackets and it worked
but i want to be able to remove the numbers from the list with out renameing them
thats why i put brackets around the numbers (0333) Bomberman Max 2 - Max Version.zip
just woundering why does this make it not work ?
Perhaps you should move the brackets to the end of the filenames? Or are you tring to use the numbers as a way to order the list? Bracketed information usually signals the beginning of extraneous information that's not desirable on the list, even information outside the brackets. That's especially true with VPinball where the the versions and revisions read like novels. So it's possible GameEx is throwing away the whole thing.
If you want to manipulate the way the list is formatted, you can use use a MAP file. GameEx creates one for you in the DATA dir (EMU_x.MAP). Copy that to another folder, edit it how you like and then set the MAP file parameter in gameex config to point to it.
